Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4616 Discussions
Where are the Power SW and Reset SW on Intel S3420GPV?
I have recently bought an Intel S3420GPV server board and some non-Intel case (Chieftec namely). I cannot find any of the common Power SW, Reset SW or Power LED jumpers on board and it looks like I will not be able to power on my server...There is any solution to this or I have to by an Intel chassis?
I would appreciate any help.
Follow up.
I've searched through S3420GP Technical Product Specification and I've found something...Table 45. Front Panel SSI Standard 24-Pin Connector Pin-out (J1C1). It would be possible to use the pin pair 11-13 (FP_PWR_BTN_N - GND) with the chassis's Power SW connector and the pin pair 15-17 (RST_FP_BTN_N - GND) with the chassis's Reset SW?
Edward_Z_Intel
Thank you. Everything is OK. My server is up and running.
Edward_Z_Intel
