Server Products
4853 Discussions
X5450 + S5000XVNSATAR
Will work two
Intel Xeon X5450 3GHz/12M/1333 Q5YQ
on S5000XVNSATAR motherboard?
Is X5450 only one cpu system processor?
From the compatibility list, you can see that the CPU X5450 is on the tested list.
http://www.intel.com/support/motherboards/server/sb/CS-022346.htm
I cannot see any reason why it should not work, assuming that the board bios is updated and you are using a compatible chassis.
http://www.intel.com/support/motherboards/server/sb/CS-022653.htm
http://www.intel.com/support/motherboards/server/sb/CS-022654.htm
All the best,
Kind Regards,
Aryan.
