Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
can not install windows server 2012 on intel server board s5500ur
amogh1
hello every one
I changed the bios to this setting :
mass storage controller configuration :
intel SAS RAID module : disabled
onboard SATA controller : enabled
SATA Mode : SW RAID
I have 2 hard that is toshiba 1T.
when I want to install windows server 2012 r2 and 2008r2,I face with this problem:
I also downlad raid driver,it detects the driver but after selecting the driver,face with this error again.
I disabled both SAS and SATA raid controller,but face with this problem again.seems not detect non of hard drives,but I can see hard in boot menu option.
David_A_Intel
I would believe you are referring to our Intel® Server Board S5520UR. Would you happen to know which server system you are using? The reason I ask is that depending on the server system you may have an Active Midplane board acting as your RAID controller instead http://www.intel.com/support/motherboards/server/sb/CS-030410.htm (Storage Options).
If the RAID controller is the onboard Intel® Server RAID Technology II (ESRT2), make sure that the drives are configured properly. Let me remind you that even if you use individual drives you would need to configure these as individual RAID 0 drives.
http://www.intel.com/support/motherboards/server/sb/CS-030492.htm Newly Added Hard Drive Not Recognized in Operating System
If needed, you may use the following http://www.intel.com/support/motherboards/server/sb/CS-034884.htm RAID Simulator Tool to assist you on configuring your RAID array.
