I want to install the new Windows SBS2011 on S3420GPV Server. But after the first reboot the install failed because the system can't detect a NIC.
Is there any work around?
Holger
Seems you'll need to load the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18388 NIC driver.
there ist now chance to load the driver befor. I can start the sbs2011 in protected mode, install the driver, but then the konfiguration assistand does not start again.
Holger
Follow these steps to install the driver:
http://technet.microsoft.com/en-us/library/cc626158.aspx http://technet.microsoft.com/en-us/library/cc626158.aspx
I found a solution.
WHile the assistand check the network, you can user Shift + F10 to start a DOS-promt. Then enter control and the Controlpanel starts. Add the Nic driver from the CD and go back to the Asisstand.
regards
Webtour
