Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
can't start server S5000VSA after turned off
I turned off server, unplugged power cables from power supply unit. Than I plugged it back and tried to start server by power button, but when I pushed power button, LED on power supply unit became red and server didn't start.
JasonT_Intel
Power supply issue ?
Was there anything that was replaced when you did the power down/unplugging steps ? What chassis are you using ?
No, I just turned off server and unplug power cables, today I have connected power supply 600W and server had started, But didn't work properly I think there not enough power.
JasonT_Intel
There is a list of http://www.intel.com/support/motherboards/server/s5000vsa/sb/CS-022704.htm compatible chassis that may help you with determining which chassis to use. The http://www.intel.com/support/motherboards/server/sb/CS-022646.htm power budget tool is also something that you can use to compute for power requirements depending on what peripherals you use.
