Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4504 Discussions
how can i save configure switch on Intel Modular Server
cnguy15
Hi every one!
Please help me this case, I use a Intel Modular Server,
When i configure Switch on the Modular server, i could not save configure.
after switch restart, the switch does not save my configre and go to factory default
How can i save the switch
thanks
Hi Cuong955,
Please provide me with more details of your issue. Let me know the model of your modular server and switch; additionally, let me know what type of information you are trying to keep on the server. Include operating system, type of RAID configuration (if available).
Mike C
cnguy15
Dear Mike C!
Thanks for your reply
My Server is MFSYS25V2
Serial Number is BZMD13300299.
Firmware Chasic : 10.4.100.20110602.29753
Firmware Server :
BMC Firmware : 1.26.3
BMC Boot : 0.28
BIOS : S5500.86B.01.20.0055.050420111308
Firmware Switch : 1.0.0.27
Frimware Storage Module : 3.08.0140.08
Feature Activation
I configured 5 vlans and configured port EXT10 is a Trunk port and configure access port for NIC on Server thought Advanced Configuration, after that I save configure and then everything working is good, but when i tried restart switch, The switch go to factory defautl.
I do not know if the feature will affect the save configure or not
Hi Cuong955,
There are 2 newer versions of the Unified Firmware Update for the Intel® Modular Server System MFSYS25V2. They are versions 10.16 and 10.18.
The v.10.16 includes the newer Switch Firmware: 1.0.0.28.
https://downloadcenter.intel.com/download/21637/Firmware-update-for-Intel-Modular-Server-System-MFSYS25V2-only?product=55601 Firmware update for Intel® Modular Server System MFSYS25V2 only v 10.16
https://downloadcenter.intel.com/download/23202/Firmware-update-for-Intel-Modular-Server-System-MFSYS25V2-only?product=55601 Firmware update for Intel® Modular Server System MFSYS25V2 only v 10.18
Please review the release notes for special conditions https://downloadmirror.intel.com/21637/eng/v10_16_Install_Instructions_Release_Notes.pdf Intel® Modular Server System MFSYS25V2 v10.16 Unified Firmware Update
The support on this system is limited; Intel stopped supporting it, in November 2013. You can find all the documentation available in the link below.
https://downloadcenter.intel.com/product/55601/Intel-Modular-Server-System-MFSYS25V2 Downloads for Intel® Modular Server System MFSYS25V2
https://www.intel.com/content/www/us/en/search.html?keyword=MFSYS25V2&toplevelcategory=Support&query=MFSYS25V2&filters=Target%20Audience/Support Intel® Support - MFSYS25V2
Mike C
Hi Cuong955,
I am following your case. Let me know if my last workaround improved the performance of your system.
Mike C
cnguy15
i'm sorry for later
i have downloaded fimrware but i can not update for chassic
when upload complete as image bellow
i reboot cmm but it sill old firmware
Hi Cuong955,
This system is no longer supported through our interactive support such as phone, email, or community support forums. My best suggestion is reviewing the instructions of https://downloadmirror.intel.com/21637/eng/v10_16_Install_Instructions_Release_Notes.pdf Intel® Modular Server System MFSYS25V2 v10.16 Unified Firmware Update Release Notes & Installation Instructions. Follow the instructions in chapter B. General Information.
I hope this document helps you.
Mike C
cnguy15
Thanks for your help!
but all documents could not resolve my problems (upload firmware doesn't work, save configure network doesn't work)
Hello Cuong955
You may want to go to firmware version https://downloadcenter.intel.com/download/20855/Firmware-update-for-Intel-Modular-Server-System-MFSYS25V2-only?product=29870 10.9 and see if it helps. I would recommend connecting a client system directly to the CMM instead of doing the update over the network. This might help complete the update process. In the past, we had had customers updating the firmware with the CMM only and then adding the remaining components to complete the update process individually.
David A.
Hello Cuong955,
I was wondering if you were able to follow the steps mentioned before. Feel free to reach out if you need anything else.
David A.
Hi there,
I was wondering if you were able to follow the recommendations provided earlier. Feel free to reach out if you need anything else.
David A.
cnguy15
i have tried many time for your intruction (connect direct pc to CMM) but it still does not work.
sorry for later but i don't have many time for that,
I will send you a direct message to see if we can arrange a call from our team to address this for you. Would this be possible?
Hi there,
I was wondering if you have tried power cycling the unit and then start the update with just the CMM and then add the rest of the components one at the time.
David A.
Hi there,
I was wondering if you were able to follow the last recommendations we provided about trying the update with the CMM only to see if the update is completed it that way.
David A.
cnguy15
thanks for your help, if you can, may be contacts direct to my manager, his email or cell phone : +
AlHill
You really should remove the email address and phone number to avoid all kinds of abuse.
Doc
Hello Cuong955
I will recomendto remove the email and phone number from the forum to avoid abuse.
If your manager requieres a contact the best option will be to open a ticket directly to the server support team
https://www.intel.com/content/www/us/en/support/contact-support.html
Best Regards
Henry A.
