In github repo "intel_fpga_bbb", there are several samples for us to refer. However, I do not find any examples containing IP. So, what should we do if we want to use IP in our project?
From my perspective, what we should do is generate IP with Quartus Prime Pro and mv to "rtl/avalon" directory. But how should we modify sources.txt file, which records the source code of the project.
- Tags:
- intel-fpga-bbb
- ip
- OPAE
May I know which board are you targeting?
-Hazlina
Thanks for your reply.I am working on vLab Academic Cluster and the board should be D5005 Programmable Acceleration Cards. Its class name is fpga-pac-s10.
![](/skins/images/4399995709D76C02984DDB9A1DB96C28/responsive_peak/images/icon_anonymous_message.png)
Topic Options
