Had one hard drive fail. It was a Seagate ST3250310AS. I replaced both old discs with Seagate ST3250310CS discs. Now, I get iaStor timeout errors in Win 2003 (event 9) right after the SQL server does a database backup (~20GB). Sometimes the PC locks up upon completion of the backup. Do I have bad discs? Do I need to upgrade software/driver for the controller? Below is the error event and the report from the Intel Matrix Storage Console. Thanks.
ERROR (follows the backup every time)
Event Type:InformationEvent Source:SQLISPackageEvent Category:NoneEvent ID:12288Date:2/18/2015Time:4:00:05 AMUser:NT AUTHORITY\SYSTEMComputer:DATABASESERVERDescription:
Package "Backup to Local Drive - Daily Mon-Sat" started.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp http://go.microsoft.com/fwlink/events.asp.
Event Type:InformationEvent Source:MSSQLSERVEREvent Category:(6)Event ID:18264Date:2/18/2015Time:4:14:17 AMUser:NT AUTHORITY\SYSTEMComputer:DATABASESERVERDescription:
Database backed up. Database: SODatabase, creation date(time): 2009/02/19(14:30:51), pages dumped: 2519707, first LSN: 2061251:197:132, last LSN: 2061251:478:1, number of dump devices: 1, device information: (FILE=1, TYPE=DISK: {'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\Backup\SODatabase\SODatabase_backup_201502180400.bak'}). This is an informational message only. No user action is required.
Data:
0000: 58 47 00 00 0a 00 00 00 XG......
0008: 0f 00 00 00 44 00 41 00 ....D.A.
0010: 54 00 41 00 42 00 41 00 T.A.B.A.
0018: 53 00 45 00 53 00 45 00 S.E.S.E.
0020: 52 00 56 00 45 00 52 00 R.V.E.R.
0028: 00 00 07 00 00 00 6d 00 ......m.
0030: 61 00 73 00 74 00 65 00 a.s.t.e.
0038: 72 00 00 00 r...
Event Type:ErrorEvent Source:iaStorEvent Category:NoneEvent ID:9Date:2/18/2015Time:4:17:57 AMUser:N/AComputer:DATABASESERVERDescription:
The device, \Device\Ide\iaStor0, did not respond within the timeout period.
Data:
0000: 0f 00 05 00 01 00 6a 00 ......j.
0008: 00 00 00 00 09 00 04 c0 .......À
0010: 01 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 00 00 00 00 02 .....
REPORT
System Information
Kit Installed: 6.2.1.1002
Kit Install History: 6.2.1.1002
Shell Version: 6.2.1.1002
OS Name: Microsoft(R) Windows(R) Server 2003 for Small Business Server
OS Version: 5.2.3790 Service Pack 2 Build 3790
System Name: DATABASESERVER
System Manufacturer: Intel
System Model: S3000AH
Processor: Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz
BIOS Version/Date: Intel Corporation S3000.86B.02.00.0044.071120071047, 07/11/2007
Language: ENU
Intel(R) RAID Technology
Intel RAID Controller: Intel(R) 82801GR/GH SATA RAID Controller
Number of Serial ATA ports: 4
RAID Option ROM Version: 5.6.2.1002
Driver Version: 6.2.1.1002
RAID Plug-In Version: 6.2.1.1002
Language Resource Version of the RAID Plug-In: 6.2.1.1002
Create Volume Wizard Version: 6.2.1.1002
Language Resource Version of the Create Volume Wizard: 6.2.1.1002
Create Volume from Existing Hard Drive Wizard Version: 6.2.1.1002
Language Resource Version of the Create Volume from Existing Hard Drive Wizard: 6.2.1.1002
Modify Volume Wizard Version: 6.2.1.1002
Language Resource Version of the Modify Volume Wizard: 6.2.1.1002
Delete Volume Wizard Version: 6.2.1.1002
Language Resource Version of the Delete Volume Wizard: 6.2.1.1002
ISDI Library Version: 6.2.1.1002
Event Monitor User Notification Tool Version: 6.2.1.1005
Language Resource Version of the Event Monitor User Notification Tool: 6.2.1.1005
Event Monitor Version: 6.2.1.1005
Array_0000
Status: No active migration(s)
Hard Drive Write Cache Enabled: Yes
Free Space: 0 GB
Number of Hard Drives: 2
Hard Drive Member 1: ST3250310CS
Hard Drive Member 2: ST3250310CS
Number of Volumes: 1
Volume Member 1: Array0
Array0
Status: Normal
System Volume: Yes
Volume Write-Back Cache Enabled: No
RAID Level: RAID 1 (mirroring)
Parent Array: Array_0000
Hard Drive 0
Usage: Array member
Status: Normal
Device Port: 0
Device Port Location: Internal
Current Serial A...
- Tags:
- Conferences & Events
While I was waiting for a reply yesterday, I found a few articles about issues with LPM and Intel's controllers. Following that discovery I added some keys to the registry (see "REGISTRY FIX" below). Last night, the backup ran again. I just took a look at the Event Viewer and the errors are gone.
I know my drivers and BIOS are definitely out of date. The server machine rarely gets touched as its purpose is to run a database for Microsoft Dynamic RMS for a 24/7 convenience store. I find it odd that this issue presented itself in the first place, as the replacement drives are almost identical to the old ones. I will check back tomorrow and verify that errors are gone. If they come back, I will follow the advise in the previous reply.
REGISTRY FIX
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port0]
"LPM"=dword:00000000
"LPMDSTATE"=dword:00000000
"DIPM"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port1]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port3]
According to the report you sent us the drives are working fine. As a recommendation, please make sure you have the latest BIOS and latest ESRT2 driver from our download center.
REGISTRY FIX
Thanks for the feedback and keep in mind the recommendations given before.
Another day has passed, and still error free. Thanks for looking Dan. I'm going to mark this as answered but I will also provide links to the software updates that are recommended.
Intel® Matrix Storage RAID Driver for Windows
http://downloadcenter.intel.com/download/12528/Intel-Matrix-Storage-RAID http://downloadcenter.intel.com/download/12528/Intel-Matrix-Storage-RAID
Intel® Server Board S3000AH BIOS Update Package
http://downloadcenter.intel.com/download/19157/S3000AH-BIOS-Update-Package http://downloadcenter.intel.com/download/19157/S3000AH-BIOS-Update-Package
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
