I have a motherboard with on board graphics card, and when i run psychtoolbox (is a program running by matlab and makes visual stimulus,for research purpose) , i get a problem that SYNCHRONIZATION FAILURE due to the graphic card.When i run it on nvidia i do not get this problem.
Any suggestions are welcome
thanks a lot
If you don't get much response from the Server community, you can also try the Graphics community over at
Thanks for your reply,
The problem is that matlab-psychtoolbox is working in the pc but i would like to run it in a projector and in the projector is not working,
Do i need to make any changes in the control of the graphic card???
thank in advance
That is exactly the type of question I'd recommend asking the Graphics community.
![](/skins/images/7FDC486457F5FB4D87FED5D8C92AC987/responsive_peak/images/icon_anonymous_message.png)
