I would like to build an high capacity server with an S5000PSL server board.
Can you tell me what the max capacity per HDD is (using SATA drives), 4 drives in an RAID configuration?
(e.g. is it possible to use 2TB SATA drives?, I can't find any of these types in the tested drives list)
I only see 1 TB drives at http://www.intel.com/support/motherboards/server/sb/CS-022650.htm
Western Digital WD1002FBYS and Hitachi HDS721010KLA330, for example
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
