Is there a document that defines the non standard (oem?) IPMI commands for the use with the server board S2600WT2R.
I'm looking for how to access the I2C on a PCIe card to read some sensors on the board.
I'm using the ipmitool raw command.
Hello John,
Let me check on that. I am not aware of the possible command you can use for this purpose. Let me further investigate this and get back to you.
Thanks, for looking in to it.
I was trying to use "Slot IPMB" (51h),
does the S2600WT2R support it?
I am setting this up. I will get back to you with the results.
