Hi,here is my question:
1.the jumper"POWER ALLWAYS PRESENT"(J323),what it's use for?
2.the jumper“ALL NODE OFF”(J8J2),what it's use for?
3.In the install PDF document,there is an "PSU"controler adapter,what it's pins define?
regards
Visirs
Hello visirs,
Thank you for joining the community.
We will merge this thread with the following one as per our standard procedure.
https://forums.intel.com/s/question/0D50P00004eVJOz
Jose A.
Intel Customer Support
Hi,Joka, That's fine.Thanks.And hope you can help me to solve it. with regard Visirs------------------ 原始邮件 ------------------
