Software Archive
Read-only legacy content
17061 Discussions
A solution to the F200 camera stopping
Andrew_S_4
Hey all,
I recently bought an Intel Realsense F200 which I have been trying to setup on my Clevo P750ZM laptop (Intel 4th gen 4790K). I am running Windows 10 build 10162.
After getting the Depth Camera software installed, and installing the SDK every time I tried using the Depth Camera the light would come on for a second and then stop. I tried connecting a USB 3.0 powered hub but it still wouldn't work.
I was nearly at the point of considering the F200 defective, when I found this post about downgrading the USB 3.0 drivers on Windows 8 to the Windows 7 Intel USB drivers. I went through the process (disabling driver signing, reboot, install Intel USB driver, disable driver signing, reboot, install Intel USB root hub driver) and lo and behold it now works perfectly!!
So it appears the solution is using BOTH the Window 7 Intel USB 3.0 drivers and a powered USB 3.0 hub.
Cheers,
Andrew
Colleen_C_Intel
Thanks for the information!!
Wolfgang_F_
in my operating system 8.1 I downgraded the USB3.0 driver, but when I started DCM installation, it failed everyone by code -4.
I downloaded the newest DCM driver v1.4 in a new system 8.1. It failed by the same code in component 1 of 13.
What means the code -4? Perhaps is there a hardware defect by the new F200 camera? I've tried many but without anybody access.
Wolfgang_F_
today I updated the latest Intel HD Graphic Driver v15.36.21.64.42.22 with the Intel Update Utility and then I installed the newest DCM Driver v1.4, and ...
...finally now the F200 Camera is working!!!
romain_d_1
What does the HD graphic driver has to do with the USB ? Are you sure the update utility didn't update your USB driver ?
Cheers
