first tried crosswalk Android success [means apk Not vulnerable?] but too large files...Android plain should be the same?
I GOT below. WHEN NEW UPGRADE OF XDK IDE TO HANDLE THIS?
ALSO when use Cordova CLI 3.5.1 reuired 1)have config.xml, 2)delete xdk config files?
- Building a Cordova 3.3 application.
- Warning: Because of security vulnerabilities found in previous versions of Cordova for Android, it is recommended that you build your application with Cordova CLI 3.5. Google has indicated that applications with vulnerabilities that expose users to a risk of compromise may be removed from their app store. Other Cordova platforms such as iOS and Windows 8 are unaffected by this security risk. See this Apache Cordova Android 3.5.1 announcement for more details.
- The application name is "DDDDDDD"
- The package name is "org.DDDDD.YYYYY"
- Error: Plugin "org.apache.cordova.network-information" (0.2.8) failed to install.
- Tags:
- HTML5
- Intel® XDK
I'm told it should be fixed now. Could you give it another try?
Thanks!
Dale
What fixed? cordova 3.3 only supported by xdk ide?
can use and 3.5.1 with xdk ide or required using CLI TOOLS of cordova?
is normal a build crosswalk app to be big in MBs?
ALSO when use Cordova CLI 3.5.1 required 1)have config.xml, 2)delete xdk config files?
well
The build for 3.3 was fixed. The inclusion of the plugin should now work.
You can build with Cordova 3.3, 3.5, or 4.1.2. You should not need the CLI tools locally.
Eric
This fix is on the xdk server, so my IDE NOT needed update?
How build for upper 3.3 cordova? where to choose it? exist drop down menu, or text-box?
I updated Intel XDK IDE today...
well
In Crosswalk builds needed setup Cordova version? how they work?
Plain Android Builds (Not crosswalk) in what version numbers can set Cordova CLI Version...?
Is the same CLI cordova but in this case used in xdk?
