Hi all,
I made an application in XDK using HTML5, in this app there are many presentations indifferent dates and different time. What I want to do, is when the user click on one of these presentations, the app add an event on the calendar with the presentation date and time.
How can I do this on the XDK??
- Tags:
- HTML5
- Intel® XDK
You need a Cordova plugin like this:
https://github.com/EddyVerbruggen/Calendar-PhoneGap-Plugin
There are some Javascript examples.
Diego
You will have to use a plugin as suggested by Diego.
But before you can do that, you need to make your app a Cordova app.
Go to the Project tab -> Under Project Info -> In the first row click on the Cordova icon under 'Upgrade'.
This will update your app from HTML5 to Cordova. After this, you will get new options in your projects tab like the plugin manager where you can add the calendar plugin.
As suggested by Anusha adding on to it please see this documentation which shows how to add third party plugin:
https://software.intel.com/en-us/xdk/docs/add-manage-project-plugins
Hi - my understanding (and experience at the moment) is that the Calendar add-in is not working on CLI 5.1.1. builds. See this post: https://software.intel.com/en-us/forums/intel-xdk/topic/606793
Can you try using lower version of plugin? Some new plugins are with gradle script so having some security related issue.
Hi - I've tried 4.6, 4.4. to 4.2 with no success. And this is affecting both Android and iOS builds. Gradle builds only affect Android right?
I have tried adding cordova-plugin-calendar and I also downgrade the plugin version, but in the Emulator, I have the attached message.
When I test it on my mobile, I have nothing, no errors , no success messages, no fail message, and no events is added to the calendar also
I don't know what is the problem
I built the app and I had no errors, when I tried to install it on my mobile, it asked for permissions to access calendar and I accepted.
But when I click on the button to add a calendar event, nothing happens and no event is added
I attached the message appeared on my mobile which asking for permissions
It appears the plugin is being added correctly. You should check the documentation of the plugin and see if you are calling it correctly.
thanks all,
there was error on the code under the button.
thank you very much for the quick help,from my pleasure to join this forum.
I used the calendar and it is good
but, I have an agenda (programme) which contains many session, when the user click on one of these sessions, it will be added automatically in the calendar and check attend button.
when the user exit the agenda and enter again I need to check the attend button of the sessions in the calendar(I tried findEvent function in the calendar but it is not working)
this app is available now in the store for test its name is Africa smartGrid2016
thanks in advance
Nermeen ~
This is a functionality of the plugin itself. You should refer to the documentation of the plugin for assistance on using the findEvent function.
I already used the plugin and it is working in the create and in the delete but when I tired to use the findevent and take a result to make action, nothing happens
var startDate = new Date(2016,2,5,9,00,0,0,0);
var endDate = new Date(2016,2,5,16,00,0,0,0);
var title = "Meetings of AFSEC Technical committees";
var eventLocation = "INTERCONTINENTAL CAIRO SEMIRAMIS";
var notes = "by invitation only";
$cordovaCalendar.findEvent({
title: 'Meetings of AFSEC Technical committees',
notes: 'by invitation only',
startDate: startDate,
endDate: endDate
}).then(function (result) {
console.log('results', JSON.stringify(result, null, '\t'));
$('#toggle1').prop("checked", true);
}, function (err) {
console.error('err', err);
$('#toggle1').prop("checked", false);
please I need help to this issue, why my code is not working, and iam in a hurry as the conference will be held on 5th of March 2016
thanks in advance
Hi. i want to add an event calendar on my xdk application,
would you please help me with this request,
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
