Software Archive
Read-only legacy content
Annonces
17060 Discussions
Aero compatibility (shadow paging, SMP, x86)
hellfire
Nouveau contributeur I
880 Visites
I have implemented VMM with shadow paging. Works fine but there is a compatibility problem with Windows Aero.
When VMM is started with Windows Vista/7 x86 as a guest, the Aero stops to work (windows stop to be transparent). A message "The Desktop Window Manager has encountered a fatal error (0x8898009b)" appears in the event log.
Only SMP systems are affected, bug does not happen when guest OS is runned in UP mode.
I heard this is the common problem and major VM vendors have had to deal with it.
Can you suggest possible reasons of the problem?
Thank you!
0 Compliments
2 Réponses
David_O_Intel1
Employé
880 Visites
I was told that Windows Aero requires 3D graphics support. QEMU VGA in virtual platform does not support Direct X, thus Aero is turned off.
David Ott
0 Compliments
hellfire
880 Visites
Several existing VMM implementations (VMware Workstation, Parallels, VirtualBox) are compatible with Aero.
What should be implemented in VMM to provide Direct X support?
0 Compliments
Répondre
