Software Archive
Read-only legacy content
Ajax call blocked when installed on Android
Remi_I_
I'm trying to get my AJAX call working on the installed app.
When testing on the emulator it works fine and also works in the test tab however when I have uploaded the APK file to android and it have been uploaded onto the App Store the AJAX call does not work?
Not sure why I have also for the whitelist I have selected Cordova Android Whitelist,
The screenshot is below.
PaulF_IntelCorp
Update jQuery to version 2 and check this FAQ, might help > https://software.intel.com/en-us/xdk/faqs/app-designer#ajax-jquery-one-fail <
Marv_Y_
My attempt is to do a $.ajax(url:'url',type: 'GET' from a remote website
My Build: IntelXDK 3491
CLI: 5.4.1
Target Device:Android
I have noted the recommendation relative to jQuery upgrade here:
I am Currently using Jquery 2.2
I've experienced similar hurdle related to $.ajax calls---The result/return from the call always results in a
'readyState=1' for the return object, but no data is returned, nor is a return status logged; The domain
of the url, as well as wildcards for the subdomain  are whitelisted in my build settings; (Please note that i've
attempted the call using both the 'success' and 'complete' events of the $.ajax event list;
The  return status is never logged . If i set breakpoints corresponding to occurrences of the console.log items for
status, returnno, etc., these breakpoints are skipped.
  -If i step through the code, the result bypasses any attempt to log a return status. The
conditional check using '(IsDebug() && client!==null) is stepped into,client.toString()
is display simply as [object Object],. The enclosed screenshots lend further detail to
the content of client at the occurrence of '(IsDebug.....
I've attempted to use the snippet shown below, as well as one where no DOMParser is used to
handle returned data;
Here is the code snippet where I make the call:
var client={};
try{
client=$.ajax({
            url:'https://www.powerfocus.biz/user/powerfocusbasic3so/c/gclient_UnAuthUser.xml',
            type:'GET',
            dataType:'xml',
            error:function(xhr,textStatus,errorThrown){
                console.log("error reported: " + ':' + (errorThrown?errorThrown:'Unknown') + 'state:' + textStatus);
            complete:function(xhr,textStatus){
                client = new DOMParser().parseXML(xhr.httpResponse.data);
                 return client.toString();
            }).always(function (retorno, textStatus, jqXHR) { //;paf; see http://stackoverflow.com/a/19498463/2914328
                 console.log("jQuery version: " + $.fn.jquery) ;
                 console.log("arg1:", retorno) ;
                 console.log("arg2:", textStatus) ;
                 console.log("arg3:", jqXHR) ;
               if(retorno.status==200
                  || retorno.status > 200
                  || retorno.responseJSON!==null)
                       console.log(retorno.status);
                       console.log(JSON.stringify(retorno.responseJSON));
        if(IsDebug()
          && client!==null)
                alert("String raw string value: " + client.toString());
}catch(err){
console.log(err.message)
return client;
Marv_Y_
Regarding post: My target build is Android OS;
PaulF_IntelCorp
Marv -- are you doing this testing in the Simulate tab or in a built app or from the Debug tab or within App Preview? You will get different results in each of those environments. To test this thoroughly on a real device with a built app (which is, obviously, the most accurate condition), use the technique outlined here > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview#RemoteChromeDevTools <
