Software Archive
Read-only legacy content
17060 Discussions
Amplifier fails with fibers
George_Kotorlis
when using Amplifier with a fiber-based application I get the assertion "stack_region_bottom > stack_region_top" and then a runtime error that terminates the process.
On Vista x64 the "stack_region_top" value will not be modified when calling "SwitchToFiber()" since it does not affect the code execution.
Is it possible to remove this assertion?
George
Vladimir_T_Intel
Hello George,
Is that possible to provide us with a simple test case that would reproduce the problem?
George_Kotorlis
Here is a small example:
#include
#define MAX_FIBERS 100
LPVOID fiber[MAX_FIBERS];
void WINAPI FiberProc(LPVOID lpv)
for (;;)
SwitchToFiber(fiber[(long)lpv]);
void main()
fiber[0] = ConvertThreadToFiber(0);
for (long i = 1; i < MAX_FIBERS; ++i)
fiber = CreateFiber(0, FiberProc, (void*)((i + 1) % MAX_FIBERS));
for (;;)
SwitchToFiber(fiber[1]);
Compile it for x64 and run it. You will get immediately the assertion.
Vladimir_T_Intel
Thanks for the code sample, I'll check it soon.
Is that particularly x64 problem? Did you reproduce it on x32 system? Which compiler (VS version) you were using?
George_Kotorlis
Yes, the problem occurs only on x64 (I tested on Vista), not on x32 where SwitchToFiber() sets the stack_top value.
The compiler I used was VS2008 Professional.
Vladimir_T_Intel
Hello George,
I've reproduced the problem exactly on x64 system. Thanks again for submitting it.
We are going to fix it. Unfortunately, the bug fix won't be ready for the very next public release. So, we have to wait further releases.
Vladimir_T_Intel
Just in case this is relevant: the bug was fixed long ago in the Amplifier Update 2. Sorry for the late notification.
