Software Archive
Read-only legacy content
17060 Discussions
question about sgdt
pocdev
Hi there,
I am using `sgdt' instruction in my user space application and don't really
understand the results. The point is when I run application more time `sgdt'
doesn't return the same result every time. I am talking about returned base address of GDT which is seems to be not same every time I run the instruction. See my code below.
So my question is:
Is the GDTR content constant all the time the linux is running?
pocdevel.
#include
typedef struct {
unsigned short limit;
unsigned int base __attribute__((packed));
} gdt_t;
static inline gdt_t* inl_sgdt(gdt_t* m)
__asm__ __volatile__("sgdt %0":"=m"(*m)::"memory");
return m;
int main(void)
gdt_t gdt;
printf("--- Checking `inl_sgdt' --- ");
inl_sgdt((gdt_t*)&gdt);
printf("base: 0x%X limit: 0x%X sizeof: %d ", gdt.base, gdt.limit, sizeof(gdt));
return 0;
Now if you run the code more times you should get different values for base address (gdt.base). I my case are:
base: 0xC1813000 limit: 0xFF sizeof: 6
base: 0xC1809000 limit: 0xFF sizeof: 6
If I understand well `sgdt' instruction should store 6 bytes content of GDTR at given address (in my case &gdt). I don't understand why I get two different
values for gdt.base.
Steven_T_Intel
The same question is appearing in the thread:
http://www.osdev.org/phpBB2/viewtopic.php?p=122469&sid=22578b099869ee17b931ea9946e1c848
Another question to follow is; which distro are you running?
To Mis-quote Obi-Wan Kenobi, "Use the source Luke"! Look at the source code for the system you are running to see where a sgdt instruction is being used.
Also, it is somewhat confusing to understand why this question arrives in a forum about Virtualization.
Steven_T_Intel
Please got to Intel Customer Support email form, http://supportmail.intel.com/scripts-emf/welcome.aspx
for further information on your question
strictlymike
I realize this thread is very old, but I was interested too and the post on osdev didn't satisfy me. I suspected the behavior you saw was due to your code running on multiple CPUs.
I wrote a kernel module (attached tarball) to test this by running a function on each CPU to dump the GDT. The results (reproduced here for convenience) were consistent with my theory:
[plain]CPU 1: Storing GDT...
CPU 1:     GDT base  = 0xc211e000
CPU 1:     GDT limit = 0x      ff
CPU 0: Storing GDT...
CPU 0:     GDT base  = 0xc2018000
CPU 0:     GDT limit = 0x      ff
[/plain]
CPU #1 and CPU #0 on my system invariably report these two GDT base addresses, respectively. At least in my case, that seems to explain the matter--one GDT per CPU.
duzyatko2yahoo_com
Thank you for the information. It is very helpful for me.
strictlymike
Glad to hear it! Do feel free to rate my answer if you found it to be helpful ;-)
