Software Archive
Read-only legacy content
公告
17060 讨论
An error occurred while building the application. Verify your build assets are correct and try again.[iOS]
Jure_C_
初学者
1,753 次查看
I have HTML5 + CORDOVA + Ionics project, INTEL XDK version is 1995.
Project name is IonTest. I tryed to build application under the name: SOLINTERRA #1, SOLINTERRA, IonTest.
I can build my application without a problem for Android. But when I try to build it for iPhone I get An error occurred while building the application. Verify your build assets are correct and try again.
I have added p12,provisionig profile...
When in test, I could build a .ipa file.
0 项奖励
1 解答
PaulF_IntelCorp
1,753 次查看
Try to limit your use of the intel.xdk APIs, they are going away and are based on very old implementations of PhoneGap. The equivalent Cordova APIs are a better choice, including use of the "deviceready" event instead of that "intel.xdk.device.ready" event to detect initialization of the Cordova subsystem.
Use the Cordova "StatusBar" plugin (last plugin in the leftmost column of plugins in the Plugins section of the Projects tab) instead of intel.xdk.device.hideStatusBar().
I have never seen this network alert, you may need to do some further debugging to determine where that is coming from.
在原帖中查看解决方案
0 项奖励
11 回复数
Amrita_C_Intel
1,753 次查看
Can you please provide with your build log?
0 项奖励
Jure_C_
初学者
1,753 次查看
where can I find build log? I have the same screen as the person that created this thread: https://software.intel.com/en-us/forums/topic/558489
0 项奖励
PaulF_IntelCorp
1,753 次查看
Are you using a dev or production provisioning file? You need to use an ad-hoc provisioning file for testing.
0 项奖励
Amrita_C_Intel
1,753 次查看
Are you using the classic (legacy) build or the Cordova build or iOS?
0 项奖励
Amrita_C_Intel
1,753 次查看
You can see the error log just below the build failed message if you are using Cordova build.
0 项奖励
Jure_C_
初学者
1,753 次查看
@Paul Fischer
I tried both dev and production profiles.
@Amrita C.
I am using Cordova build. And there is no error log.
I tried another build so that I could make a screenshot for Amrita about the build log and now application was build. I hope that I will have enough time to try it today and that it will work without problems. I will replay if there will be more problems, but thank you for your help.
0 项奖励
Jure_C_
初学者
1,753 次查看
I have to problems with my app. If I should  open a new thread, please tell me.
First problem is that on iPhone 4, iOS 7.1.1 I can't hide status bar. For that purpose I use this code in index.html
<script>
    var onDeviceReady=function(){
        //alert("device ready");
                //----------- Set device orientation -----------------------
                intel.xdk.device.setRotateOrientation("landscape");
                intel.xdk.device.setAutoRotate(false);
                //----------- Hide status bar ------------------------------
                intel.xdk.device.hideStatusBar();
document.addEventListener("intel.xdk.device.ready",onDeviceReady,false);
    </script> -->
Second problem have been encountered on both Android and iOS, when you load the application for the first time, it will fire alert that it you should check internet connection. This alert gets fired if app doesn't retrive data from web api in 5 secconds. If you close the app and run it again, it works fine.Second problem have been encountered on both Android and iOS, when you load the application for the first time, it will fire alert that it you should check internet connection. This alert gets fired if app doesn't retrieve data from web api in 5 seconds. If you close the app and run it again, it works fine.
0 项奖励
PaulF_IntelCorp
1,754 次查看
0 项奖励
Jure_C_
初学者
1,753 次查看
That alert is alert that I display, when trigger for connection timeout is triggered.
I will change intel.xdkAPIs with Cordova APIs.
EDIT: Now that I changed APIs, status bar is hidden, like it should be. But still I don't know why I get that connection alert.
Thank you.
0 项奖励
Matthew_S_8
初学者
1,753 次查看
I too got the same error. this is my build log
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar" => ".../GlobalApp/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-statusbar" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":32,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":33,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":34,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":35,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":38,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":39,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":40,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":41,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":42,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":44,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":45,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":46,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":47,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":48,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":49,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":50,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":51,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":52,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":53,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":54,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":55,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":56,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":57,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":58,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":59,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":60,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":61,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":62,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":63,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]},".../GlobalApp/plugins/cordova-plugin-statusbar":{"filepath":".../GlobalApp/plugins/cordova-plugin-statusbar/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-statusbar","_et":{"_root":{"_id":64,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":65,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":66,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":67,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":68,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":69,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":70,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":71,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":72,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":74,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":75,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":76,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":77,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":78,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":79,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":82,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":83,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":84,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":85,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":86,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":87,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":88,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":89,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":90,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":91,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":92,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":93,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":94,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":95,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":96,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":97,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":98,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":99,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":100,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-statusbar" for ios
Running command: .../GlobalApp/platforms/ios/cordova/version
Command finished with error code 0: .../GlobalApp/platforms/ios/cordova/version
Install start for "cordova-plugin-statusbar" on ios.
Beginning processing of action stack for ios project...
Parsing ios project files...
Action stack processing complete.
Writing out ios project files...
Preparing ios project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'cordova-plugin-statusbar' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-statusbar on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device" => ".../GlobalApp/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-device" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":32,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":33,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":34,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":35,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":38,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":39,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":40,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":41,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":42,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":44,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":45,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":46,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":47,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":48,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":49,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":50,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":51,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":52,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":53,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":54,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":55,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":56,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":57,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":59,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":60,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":61,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":62,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":63,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":64,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":66,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":68,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":69,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":70,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":71,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":72,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":73,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":74,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":75,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":76,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":77,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":78,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":79,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":82,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":83,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":84,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":85,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":86,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":87,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":88,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":89,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":90,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":91,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":92,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":93,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":94,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]},".../GlobalApp/plugins/cordova-plugin-device":{"filepath":".../GlobalApp/plugins/cordova-plugin-device/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-device","_et":{"_root":{"_id":95,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":96,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":97,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":98,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":99,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":100,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":101,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":102,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":103,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":104,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":105,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":106,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":107,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":108,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":109,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":110,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":112,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":113,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":114,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":115,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":116,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":117,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":118,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":119,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":120,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":121,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":122,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":123,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":124,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":125,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":126,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":127,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":128,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":129,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":130,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":131,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":132,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":133,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":134,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":135,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":136,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":137,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":138,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":139,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":140,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":141,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":142,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":143,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":144,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":145,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":146,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":147,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":148,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":149,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":150,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":151,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":152,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":153,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":154,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":155,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":156,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":157,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":158,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":159,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":160,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":161,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":162,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-device" for ios
Install start for "cordova-plugin-device" on ios.
Iterating over installed plugins: [ 'cordova-plugin-statusbar', 'cordova-plugin-device' ]
Install complete for cordova-plugin-device on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen" => ".../GlobalApp/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-splashscreen" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":32,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":33,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":34,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":35,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":38,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":39,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":40,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":41,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":42,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":43,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":46,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":47,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":48,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":49,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":50,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":51,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":52,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":53,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":54,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":55,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":56,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":57,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":60,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":61,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":62,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":63,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":64,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":65,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":66,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":68,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":69,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":70,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":71,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":74,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":75,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":76,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":77,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":78,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":79,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":81,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":82,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":83,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":84,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]},".../GlobalApp/plugins/cordova-plugin-splashscreen":{"filepath":".../GlobalApp/plugins/cordova-plugin-splashscreen/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-splashscreen","_et":{"_root":{"_id":85,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":86,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":87,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":88,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":89,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":90,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":91,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":92,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":93,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":94,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":95,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":96,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":97,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":98,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":99,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":100,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":101,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":102,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":103,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":104,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":105,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":106,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":107,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":108,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":109,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":110,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":112,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":113,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":114,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":115,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":116,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":117,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":118,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":119,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":120,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":121,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":122,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":123,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":124,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":125,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":126,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":127,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":128,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":129,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":130,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":133,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":134,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":135,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":136,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":137,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":138,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":139,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":140,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":141,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":142,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-splashscreen" for ios
Install start for "cordova-plugin-splashscreen" on ios.
  'cordova-plugin-device',
  'cordova-plugin-splashscreen' ]
Install complete for cordova-plugin-splashscreen on ios.
Generating config.xml from defaults for platform "ios"
Calling plugman.prepare for platform "ios"
Wrote out iOS Bundle Identifier to "namo.global.app.sridhar"
Wrote out iOS Bundle Version to "0.0.1"
iOS Product Name has not changed (still "GlobalApp")
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../GlobalApp]
Will process and update the following config files:
    Config.xml = [.../GlobalApp/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [GlobalApp]
Updating full app name to [GlobalApp]
Processing preference permissions
Updating the versionName
Setting [CFBundleShortVersionString] to 0.0.1
Processing debuggable
Processing config file values
Saving config.xml to [.../GlobalApp/config.xml]
Saving info.plist to [.../GlobalApp/platforms/ios/GlobalApp/GlobalApp-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../GlobalApp/platforms/ios/cordova/build --release --device
Building project  : .../GlobalApp/platforms/ios/GlobalApp.xcodeproj
	Configuration : Release
	Platform      : device
Build settings from command line:
    ARCHS = armv7 armv7s arm64
    CONFIGURATION_BUILD_DIR = .../GlobalApp/platforms/ios/build/device
    SDKROOT = iphoneos8.0
    SHARED_PRECOMPS_DIR = .../GlobalApp/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 armv7s arm64
Build settings from configuration file '.../GlobalApp/platforms/ios/cordova/build-release.xcconfig':
    CODE_SIGN_IDENTITY = iPhone Distribution
    IPHONEOS_DEPLOYMENT_TARGET = 5.1.1
    PROVISIONING_PROFILE = 55dfc0c1-840f-44bb-aa44-dda3f0042994
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-fivrigwvgybezearyxkqepphqwui
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-fivrigwvgybezearyxkqepphqwui/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-ewmbvtliszxykhdqazocuxzlgdis
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-ewmbvtliszxykhdqazocuxzlgdis/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-efvxvmjhiwhimmbjxfdnmvsssihe
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-efvxvmjhiwhimmbjxfdnmvsssihe/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
CpHeader Classes/CDVInvokedUrlCommand.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    cd .../GlobalApp/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSMutableArray+QueueAdditions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPlugin.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVPlugin.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVDebug.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVDebug.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVDebug.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSData+Base64.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSData+Base64.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSData+Base64.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSDictionary+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSDictionary+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPluginResult.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVPluginResult.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWhitelist.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVWhitelist.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVURLProtocol.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVURLProtocol.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVViewController.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVViewController.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDV.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDV.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDV.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailability.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVAvailability.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailabilityDeprecated.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVAvailabilityDeprecated.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/UIDevice+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/UIDevice+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVLocalStorage.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVLocalStorage.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVLocalStorage.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSArray+Comparisons.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSArray+Comparisons.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandQueue.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandQueue.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVShared.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVShared.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVShared.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegateImpl.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVScreenOrientationDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVScreenOrientationDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVConfigParser.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
0 项奖励
PaulF_IntelCorp
1,753 次查看
@Matthew -- please do not paste those build logs into your post, they are extremely difficult to scan when you do that, making it very difficult to help you. Please attach the detailed build log using the "attach media" button. That insures we get the original file with no modifications. Please try again.
0 项奖励
回复
