Software Archive
Read-only legacy content
17060 Discussions
An unexpected error occured while attempting to build the application.
Yigitcan_H_
Help !
Logs:
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.JcpX7r.pl/org.apache.cordova.camera"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.JcpX7r.pl/org.apache.cordova.camera" => ".../AstermDepo/plugins/org.apache.cordova.camera"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.camera" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.camera" for android
Install start for "org.apache.cordova.camera" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/camera
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Running command: .../AstermDepo/platforms/android/cordova/version
Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'org.apache.cordova.camera' ]
Writing out cordova_plugins.js...
Install complete for org.apache.cordova.camera on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.mGnKze.pl/org.apache.cordova.device"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.mGnKze.pl/org.apache.cordova.device" => ".../AstermDepo/plugins/org.apache.cordova.device"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.device" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.device" for android
Install start for "org.apache.cordova.device" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/device
Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device' ]
Install complete for org.apache.cordova.device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.BymvdD.pl/org.apache.cordova.inappbrowser"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.BymvdD.pl/org.apache.cordova.inappbrowser" => ".../AstermDepo/plugins/org.apache.cordova.inappbrowser"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.inappbrowser" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.inappbrowser" for android
Install start for "org.apache.cordova.inappbrowser" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/inappbrowser
path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_next_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_next_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_next_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_next_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_previous_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_previous_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_previous_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_previous_item.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_remove.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_remove.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_remove.png
path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-hdpi/ic_action_next_item.png to res/drawable-hdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_next_item.png to res/drawable-mdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_next_item.png to res/drawable-xhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_next_item.png to res/drawable-xxhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_previous_item.png to res/drawable-hdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_previous_item.png to res/drawable-mdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_previous_item.png to res/drawable-xhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_previous_item.png to res/drawable-xxhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_remove.png to res/drawable-hdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-mdpi/ic_action_remove.png to res/drawable-mdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_remove.png to res/drawable-xhdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_remove.png to res/drawable-xxhdpi/ic_action_remove.png
  'org.apache.cordova.device',
  'org.apache.cordova.inappbrowser' ]
Install complete for org.apache.cordova.inappbrowser on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.LOhyrT.pl/org.apache.cordova.dialogs"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.LOhyrT.pl/org.apache.cordova.dialogs" => ".../AstermDepo/plugins/org.apache.cordova.dialogs"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.dialogs" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.dialogs" for android
Install start for "org.apache.cordova.dialogs" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/dialogs
  'org.apache.cordova.inappbrowser',
  'org.apache.cordova.dialogs' ]
Install complete for org.apache.cordova.dialogs on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.aWa1At.pl/org.apache.cordova.splashscreen"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.aWa1At.pl/org.apache.cordova.splashscreen" => ".../AstermDepo/plugins/org.apache.cordova.splashscreen"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.splashscreen" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.splashscreen" for android
Install start for "org.apache.cordova.splashscreen" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/splashscreen
  'org.apache.cordova.dialogs',
  'org.apache.cordova.splashscreen' ]
Install complete for org.apache.cordova.splashscreen on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.lfLkW8.pl/org.apache.cordova.statusbar"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.lfLkW8.pl/org.apache.cordova.statusbar" => ".../AstermDepo/plugins/org.apache.cordova.statusbar"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.statusbar" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.statusbar" for android
Install start for "org.apache.cordova.statusbar" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/statusbar
  'org.apache.cordova.splashscreen',
  'org.apache.cordova.statusbar' ]
Install complete for org.apache.cordova.statusbar on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.kxS6AP.pl/org.apache.cordova.battery-status"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.kxS6AP.pl/org.apache.cordova.battery-status" => ".../AstermDepo/plugins/org.apache.cordova.battery-status"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.battery-status" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.battery-status" for android
Install start for "org.apache.cordova.battery-status" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/batterystatus
  'org.apache.cordova.statusbar',
  'org.apache.cordova.battery-status' ]
Install complete for org.apache.cordova.battery-status on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.hArx16.pl/org.apache.cordova.device-motion"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.hArx16.pl/org.apache.cordova.device-motion" => ".../AstermDepo/plugins/org.apache.cordova.device-motion"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.device-motion" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.device-motion" for android
Install start for "org.apache.cordova.device-motion" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/devicemotion
  'org.apache.cordova.battery-status',
  'org.apache.cordova.device-motion' ]
Install complete for org.apache.cordova.device-motion on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.IUpVlq.pl/org.apache.cordova.network-information"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.IUpVlq.pl/org.apache.cordova.network-information" => ".../AstermDepo/plugins/org.apache.cordova.network-information"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.network-information" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.network-information" for android
Install start for "org.apache.cordova.network-information" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/networkinformation
  'org.apache.cordova.device-motion',
  'org.apache.cordova.network-information' ]
Install complete for org.apache.cordova.network-information on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.OIrgjO.pl/org.apache.cordova.geolocation"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.OIrgjO.pl/org.apache.cordova.geolocation" => ".../AstermDepo/plugins/org.apache.cordova.geolocation"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.geolocation" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.geolocation" for android
Install start for "org.apache.cordova.geolocation" on android.
  'org.apache.cordova.network-information',
  'org.apache.cordova.geolocation' ]
Install complete for org.apache.cordova.geolocation on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.cO2nvH.pl/org.apache.cordova.globalization"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.cO2nvH.pl/org.apache.cordova.globalization" => ".../AstermDepo/plugins/org.apache.cordova.globalization"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.globalization" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.globalization" for android
Install start for "org.apache.cordova.globalization" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/globalization
  'org.apache.cordova.geolocation',
  'org.apache.cordova.globalization' ]
Install complete for org.apache.cordova.globalization on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.BNYujE.pl/org.apache.cordova.file"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.BNYujE.pl/org.apache.cordova.file" => ".../AstermDepo/plugins/org.apache.cordova.file"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.file" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.file" for android
Install start for "org.apache.cordova.file" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file
  'org.apache.cordova.globalization',
  'org.apache.cordova.file' ]
Install complete for org.apache.cordova.file on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.bytEXk.pl/org.apache.cordova.media"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.bytEXk.pl/org.apache.cordova.media" => ".../AstermDepo/plugins/org.apache.cordova.media"
Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.media" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.media" for android
Dependencies detected, iterating through them...
Dependent plugin "org.apache.cordova.file" already fetched, using that version.
Dependent plugin "org.apache.cordova.file" already installed on android.
Install start for "org.apache.cordova.media" on android.
path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/media
  'org.apache.cordova.file',
  'org.apache.cordova.media' ]
Install complete for org.apache.cordova.media on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.LtUjnI.pl/com.intel.xdk.accelerometer"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.LtUjnI.pl/com.intel.xdk.accelerometer" => ".../AstermDepo/plugins/com.intel.xdk.accelerometer"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.accelerometer" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.accelerometer" for android
Install start for "com.intel.xdk.accelerometer" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/accelerometer
  'org.apache.cordova.media',
  'com.intel.xdk.accelerometer' ]
Install complete for com.intel.xdk.accelerometer on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.3r01Vr.pl/com.intel.xdk.base"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.3r01Vr.pl/com.intel.xdk.base" => ".../AstermDepo/plugins/com.intel.xdk.base"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.base" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.base" for android
Install start for "com.intel.xdk.base" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/base
path does not exist: .../AstermDepo/platforms/android/res/layout
  'com.intel.xdk.accelerometer',
  'com.intel.xdk.base' ]
path does not exist: .../AstermDepo/platforms/android/intelxdk.js
path does not exist: .../AstermDepo/platforms/android/xhr.js
Install complete for com.intel.xdk.base on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.mo0qH5.pl/com.intel.xdk.cache"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.mo0qH5.pl/com.intel.xdk.cache" => ".../AstermDepo/plugins/com.intel.xdk.cache"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.cache" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.cache" for android
Install start for "com.intel.xdk.cache" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/cache
  'com.intel.xdk.base',
  'com.intel.xdk.cache' ]
Install complete for com.intel.xdk.cache on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.lkv4Aa.pl/com.intel.xdk.camera"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.lkv4Aa.pl/com.intel.xdk.camera" => ".../AstermDepo/plugins/com.intel.xdk.camera"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.camera" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.camera" for android
Install start for "com.intel.xdk.camera" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/camera
  'com.intel.xdk.cache',
  'com.intel.xdk.camera' ]
Install complete for com.intel.xdk.camera on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.RnAoQa.pl/com.intel.xdk.device"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.RnAoQa.pl/com.intel.xdk.device" => ".../AstermDepo/plugins/com.intel.xdk.device"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.device" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.device" for android
Install start for "com.intel.xdk.device" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/device
path does not exist: .../AstermDepo/platforms/android/src/com/phonegap/plugins/barcodescanner
path does not exist: .../AstermDepo/platforms/android/res/layout-land
path does not exist: .../AstermDepo/platforms/android/res/layout-ldpi
path does not exist: .../AstermDepo/platforms/android/res/menu
path does not exist: .../AstermDepo/platforms/android/res/raw
  'com.intel.xdk.camera',
  'com.intel.xdk.device' ]
Install complete for com.intel.xdk.device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.4yc19G.pl/com.intel.xdk.display"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.4yc19G.pl/com.intel.xdk.display" => ".../AstermDepo/plugins/com.intel.xdk.display"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.display" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.display" for android
Install start for "com.intel.xdk.display" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/display
  'com.intel.xdk.device',
  'com.intel.xdk.display' ]
Install complete for com.intel.xdk.display on android.
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.J8_wcm.pl/com.intel.xdk.notification"
Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.J8_wcm.pl/com.intel.xdk.notification" => ".../AstermDepo/plugins/com.intel.xdk.notification"
Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.notification" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "com.intel.xdk.notification" for android
Install start for "com.intel.xdk.notification" on android.
path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/notification
  'com.intel.xdk.display',
  'com.intel.xdk.notification' ]
Install complete for com.intel.xdk.notification on android.
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
undefined
Yigitcan_H_
Auto Added andoid.confix.xml
<preference name="android-permission" value="&lt;preference"/>
<preference name="android-permission" value="name=&quot;android-windowSoftInputMode&quot;"/>
<preference name="android-permission" value="value=&quot;adjustResize&quot;/&gt;"/>
PaulF_IntelCorp
When adding those extra Android permissions, you need to add them by simply providing the name as shown on this page: http://developer.android.com/reference/android/Manifest.permission.html -- I'll update the doc page to remove some of that confusion.
Do you need all of those plugins? Generally, most apps do not need every plugin in the list of available plugins. Including plugins your app does not need can cause conflicts and problem. I recommend you only select those plugins that correspond to APIs your app is actually using.
