Software Archive
Read-only legacy content
17060 Discussions
Analyse error in an android build
Elie_A_
I use Intel XDK with Cordova 5.1.1 for Android. When I use the DEBUG tab, all is going good. When I build the package I get a BUILD SUCCESS. But when I try to install the package on a device (under android 4.4.4) I get the message "Analyse error in the package" and it's impossible to install the app.
This problem don't happen under Cordova 4.1.2 (but I can't use the last versions of the plugins)
My app is created from import files.
Do you see a solution for that
Thank ou
Amrita_C_Intel
Hello Elie,
For which platform are you building? Which device are you using for installing app?
Anusha_M_Intel1
Hi Ellie, Could you list the plugins you are using in the project? Let me see if I can reproduce that error. And also, as Amrita requested, the platform you are building for.
Elie_A_
I don't think it's a problem of plugins because I used exactly the same plugins in an other app and it works. The platform is Android
Elie_A_
I found the error!! If you let "not.yet.specified" for the AAP ID, all works
Anusha_M_Intel1
It looks like the app build that you were trying to install on your phone had the same app ID as some other app on your phone.
