Software Archive
Read-only legacy content
17060 Discussions
Android Build not possible
Arne_B_1
I have a problem with the build of an android App. I think the problem is the "Using plattform Android-Cordova".
Please help me.
Arne
Elroy_A_Intel
Are you able to build blank Android (Optimized with Crosswalk) projects successfully?
Jerroyd_M_Intel
Hi Arne,
Have you taken a look at your compile log? It looks like one of your assets  is not a PNG file.
:mergeReleaseResourceslibpng error: Not a PNG file
Error: Failed to run command:
	.../android-sdk/build-tools/21.1.2/aapt s -i .../ToolBoxKuP_new/platforms/android/res/drawable-xhdpi/icon.png -o .../ToolBoxKuP_new/platforms/android/build/intermediates/res/release/drawable-xhdpi-v4/icon.png
Error Code:
	42
Output:
Arne_B_1
There were jpgs in my project. I converted them to png. But the error is still there. Do I have to delet the project files from the server?
PaulF_IntelCorp
Arne -- you shouldn't have to delete the project from the server, but it wouldn't hurt. You can start with using the little garbage can icon on the build page. If that doesn't work, login to App Center to delete all entries. See this FAQ > https://software.intel.com/en-us/xdk/faqs/general#apps-in-development
Arne_B_1
The error is still there. I dont understand the error log:
	.../android-sdk/build-tools/21.1.2/aapt s -i .../ToolBoxKuP_new/platforms/android/res/drawable-xhdpi/icon.png -o .../ToolBoxKuP_new/platforms/android/build/intermediates/res/armv7/release/drawable-xhdpi-v4/icon.png
Error Code:
	42
Output:
:mergeArmv7ReleaseResources FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':mergeArmv7ReleaseResources'.
  Error Code:
  	42
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 5.758 secs
ERROR building one of the platforms: Error: .../ToolBoxKuP_new/platforms/android/gradlew: Command failed with exit code 1
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (.../ToolBoxKuP_new/platforms/android/cordova/node_modules/cordova-common/src/superspawn.js:139:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
I have no more ideas where a wrong asset can be found. Do you have some more advices?
PaulF_IntelCorp
@Arne -- how did you convert your JPG files to PNG format? Renaming them will not convert the internal format. You have to use a conversion tool or open the JPG files in an image editor and then save them as PNG formatted files. If that is what you did, it may be that the tool you used saved them in some obscure PNG format that is not being recognized.
It's hard to tell from your error message where this icon.png file is coming from (is it from your app or from a plugin). Can you provide a copy of the <project-name>.xdk file in the root of your project directory so I can see what plugins are part of your app. Also, if you could provide a ZIP of the icon image files that are in your project. Please ZIP them all together and post the ZIP as a file attachment to your next post (see the "Attach Files to Post" link below the edit window.
Arne_B_1
It works! I thought renaming is enough. ^^'
Thanks for help!
