Software Archive
Read-only legacy content
17061 Discussions
Android Crosswalk build failed with an additional config-file
Alexandre_L_
Here is the content of my "intelxdk.config.additions.xml":
<!-- +Android-Crosswalk --><config-file target="*Manifest.xml" platform="android" parent="/manifest/application/activity" mode="add">
    <intent-filter xmlns:android="http://schemas.android.com/apk/res/android">
        <action android:name="android.intent.action.SEND" />
        <category android:name="android.intent.category.DEFAULT" />
        <data android:mimeType="text/plain" />
    </intent-filter>
</config-file>
And here is the build log:
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [21]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Any idea? Thnaks!
PaulF_IntelCorp
The additions.xml file is not an AndroidManifest.xml file. You can't use Android SDK config options inside that file. It is used to direct the XDK build system, which is a slightly modified Cordova CLI build system. See these two doc pages for valid entries in that file:
Alexandre_L_
Thanks for you answer! You should add a feature like gap:config-file.
Meanwhile I added my modification directly in the plugin.
Example: https://github.com/Alexandre-io/WebIntent/commit/19cf498d6731826df4534737be4b67a6251d1f00
