Software Archive
Read-only legacy content
17060 Discussions
Android Shared Crosswalk build failing
David_R_9
When I compile any of mi Apps in Shared CrossWalk, the build fail. The same apps build correctly in any Embebed version of CrossWalk. The last day I could build in CrossWalk shared was 14th September. I only receive this message: "An error occurred while building the application. Verify your build assets are correct and try again.". No more information or log. I´m very confused because I don´t know where is the problem.
Rakshith_K_Intel
We just fixed the issue, can you try again.
Thanks for reporting!
David_R_9
It seems to be solved!!!! Thanks for your quickly response.
