Software Archive
Read-only legacy content
Apps on server!
Thomas_V_1
The app preview do not load lates version. How do I erase apps on the server?
Amrita_C_Intel
You can login here: appcenter.html5tools-software.intel.com and delete the projects (click the trash icon for the project you want to delete)
Thomas_V_1
Thanks for the answer but I only get the text:
Thank you for using the Intel® XDK.
If you are accessing this service from AppPreview, you may close the sign in window.
Anusha_M_Intel1
Hi Thomas,
Try this link: https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx
If it still doesn't work. Keep the tab open, open another tab and try the url again. This time it should work.
Amrita_C_Intel
Is your issue resolved?
Thomas_V_1
It does not work and I am logged in.
App center is just a Notice and blank
in Dev tools it's only education
in Account it's only to change password
and help is help.
In App center I get:
NOTICE: We are planning to remove access to App Center in the near future. All major functionality currently provided by App Center will be available via the Intel XDK, therefore the use of App Center should no longer be required. If you are not using the Intel XDK, you can download and install from: xdk-software.intel.com.
After installation, simply login with your current App Center credentials.
PaulF_IntelCorp
Thomas, see the image below. If you successfully log into App Center you'll see something like in the screen shot, with lists of that apps you've uploaded using the Test tab or the Build tab. If you want to delete one of those apps from the server you simply click the trash can icon (highlighted in red) to remove it from the server.
Thomas_V_1
sorry for the late response. I can not get it to load correctly. This is with chromium and xubuntu 15.04.
John_H_Intel2
You would see that screen if your account had 0 apps.
Are you sure you logged into the URL using the same login you use for the XDK?
