Software Archive
Read-only legacy content
17060 Discussions
Assumed-length character functions
Intel_C_Intel
I was searching the forum for threads on assumed-length CHARACTER functions and found a link to an e-newsletter with the following:
"Assumed-length CHARACTER functions (and the CHARACTER* form of declaration) are deemed to be an "irregularity" in the language, which they are, and there are alternatives available, but Dr. Fortran doesn't see these disappearing from users' code anytime soon."
Can anyone enlighten me on the proper Fortran 95 alternatives? I want a function that returns an integer as a character string with no leading or trailing blanks.
Andy
Intel_C_Intel
The character(*) result form will not do what you want. Here is some code that will work for and KIND of integer, although unfortunately it doesn't work in the current version of CVF. Hopefully it will work in the next release. BTW Steve, there were a couple of bugs encountered in some previous threads that weren't explicitly acknowledged as such in this forum (renaming MATMUL and improper arguments to the ASSOCIATED intrinsic.) Have these been fixed in the next version of CVF or should I send bug reports?
! File: int2string.fi
pure function int2string_len(i)
   integer int2string_len
   integer(template_kind), intent(in) :: i
   character(20) string
   write(string,'(i0)') i
   int2string_len = len_trim(adjustl(string))
end function int2string_len
function int2string(i)
   character(int2string_len(i)) int2string
   write(int2string,'(i0)') i
! End of file: int2string.fi
! File: int2string.f90
module mykinds
   implicit none
   integer, parameter :: ik1 = selected_int_kind(2)
   integer, parameter :: ik2 = selected_int_kind(4)
   integer, parameter :: ik4 = selected_int_kind(9)
   integer, parameter :: ik8 = selected_int_kind(18)
end module mykinds
module ik1_mod
   use mykinds, only: template_kind => ik1
   implicit none
   private
   public int2string
   contains
      include 'int2string.fi'
end module ik1_mod
module ik2_mod
   use mykinds, only: template_kind => ik2
   implicit none
   private
   public int2string
   contains
end module ik2_mod
module ik4_mod
   use mykinds, only: template_kind => ik4
   implicit none
   private
   public int2string
   contains
end module ik4_mod
module ik8_mod
   use mykinds, only: template_kind => ik8
   implicit none
   private
   public int2string
   contains
end module ik8_mod
module generic_recombination
   use ik1_mod, only: int2string_ik1 => int2string
   use ik2_mod, only: int2string_ik2 => int2string
   use ik4_mod, only: int2string_ik4 => int2string
   use ik8_mod, only: int2string_ik8 => int2string
   implicit none
   interface int2string
      module procedure int2string_ik1, int2string_ik2, &
                       int2string_ik4, int2string_ik8
   end interface int2string
end module generic_recombination
program int2string_prog
   use generic_recombination
   use mykinds
   implicit none
   write(*,'(a)') ' #'//int2string(-1_ik1)//'#'
   write(*,'(a)') ' #'//int2string(-1_ik2)//'#'
   write(*,'(a)') ' #'//int2string(-1_ik4)//'#'
   write(*,'(a)') ' #'//int2string(-1_ik8)//'#'
   write(*,'(a)') ' #'//int2string(huge(1_ik1))//'#'
   write(*,'(a)') ' #'//int2string(huge(1_ik2))//'#'
   write(*,'(a)') ' #'//int2string(huge(1_ik4))//'#'
   write(*,'(a)') ' #'//int2string(huge(1_ik8))//'#'
end program int2string_prog
! End of file: int2string.f90
Output (on a compiler where this works)
#-1#
#-1#
#-1#
#-1#
#127#
#32767#
#2147483647#
#9223372036854775807#
Intel_C_Intel
The 'i0' edit descriptor isn't standard, is it?
Intel_C_Intel
The 'i0' edit descriptor is standard f95. CVF supports it since v. 6.0. It's kind of difficult to find this in Compaq's documentation, though. I can see it under Index | Edit descriptors | I and then selecting 'General rules for numeric editing' at the bottom of the page, and then the behavior is in green near the bottom... probably this feature could have been more prominently documented, since I use 'i0' more than any other form of integer edit descriptor.
Steven_L_Intel1
You should always send bug reports. I don't recall the specific issues you're referring to from discussions in the forum, so it's best to send specific examples to vf-support@compaq.com. I may not catch everything written in the forum.
Steve
Intel_C_Intel
Andy,
Here is a somewhat simpler solution depending upon your needs:
CHARACTER(20) :: STRING
WRITE (STRING,'(A)') '    123456789     '
STRING = ADJUSTL(STRING)
L           = LEN_TRIM(STRING)
WRITE (*,'(A)') '#'//STRING(1:L)//'#'
The downside is that you have to access STRING with array subscripts from 1 to L everywhere you want to use this in the code.
Tom
You should easily be able to turn this into a function or a subroutine. The only downside is that you have to reference each string with (1:L)
Intel_C_Intel
Andy,
CHARACTER(30) :: STRING
OUTPUT:
#123456789#
The downside is that you have to reference STRING throughout the rest of the code using the (1:L) substring in order to eliminate the trailing blanks.
Tom
Intel_C_Intel
Sorry about the double message - sometimes this forum leaves a lot to be desired, but it is great to have anything that can be used as an additional resource.
Tom
Intel_C_Intel
Sigh...why is it so difficult to get 5 lines of code correct? Here is what I should have posted
I = 123456789
WRITE (STRING,'(I0)') I
WRITE (*,'(A)') STRING(1:L)
Tom
Intel_C_Intel
Thanks to James Van Buskirk for the program - it does work OK in CVF6.6 except that CVFseems to have a problem in generating HUGE for Integer*8 in some, but not all places. If one repllaces "huge(1_ik8)" in the last print line with "n" (without the inverted commas) where n is Integer*8 and is set to 2**63-1, you will get JVB's complete output.
Bear of little brain
Intel_C_Intel
Whoops. I assumed that this wouldn't compile due to other bugs (15493 and 15596) so I didn't actually try compiling it with CVF. Neither of them have any effect here. The bug that affects this code is new to me (16161.)
