i installed version 15.4.3 von windows vista 32-bit on my 945GM, and it causes screen flickers.
i even deinstalled it and installed the previous version (15.4) which worked just fine before. but it still flickers, seems like the 15.4.3 destroyed something, i hope its not the card!
how can intel release that driver and MS give a WHQL certificate? thats a shame.
i have a dell inspiron 640m laptop.
I am getting exactly the same problem with my D620. Everything was working fine and had no problems at all, upgraded the latest driver and now I am getting flickering screen all the time.
Tried removing the driver and installing the old one but it does not help.
And it hasn't done any harm to onboard chip because in Windows XP it's working fine.
I hope they will soon come out with a stable tested version.
There is really one thing funny about it, that is has got WHQL certification with it.
Default Microsoft Driver fixes this problem.
But after reverting back to 15.4 driver version from 15.4.3, problem still persist though intensity of flicker gets less.
They should better recall this driver as soon as possible, and the link is still up at the time of writing.
Reverting to older Intel-drivers didn't fix the issue. It could indeed be a registry value which causes this behaviour and that survives even after the installation of an older version.
Intel should fix this bug as quickly as possible since I have been seeing *many* reports of this issue popping up on various forums during the last week.
Btw, did anybody ever use the Video BIOS update from the developer package? Could updating the Video BIOS with a version from the driver package maybe fix the issue?
there is NO video biso update within the driver package.
video bios is updated along with the normal bios update
i seen the vbios files within the driver package but they are not for a bios update
It seems that Intel has removed the buggy 15.4.3 driver from their website. When I did a search, only the former 15.4.0.1255 showed up.
it fixed the flickering for me
NO thats not a solution.
in the startup and login screen it still flickers.
I very much hope that Intel will soon publish instructions how to manually fix this problem without having to do a complete system-recovery.
I installed 15.4.3 and suffered the same flickering problem, uninstalled... reinstalled...uninstalled..reinstalled a million times and the problem still existed.
Well guys, I have a solution!!! It is really easy to do and it requires no uninstalling/installing. You can keep the 15.4.3 driver and do the following.
Type in regedit in the search bar and open up the program
Find the registrykey: [HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlGraphicsDriversMemoryManager]
"FaultInjection"=dword:00000200
Delete "MemoryManager", restart your computerand it's fixed!
I have an XPS M1210 running Windows Vista Home Premium 32-Bit.
Thanks for the solution. That flickering has been driving me nuts for a week, been switching back and forth between the two drivers trying to find one that works. Even thought might be a INF problem, so tried every combination of the 2 graphics drivers and 3 inf drivers.
Fixed the flickering on my Lenovo 3000 N100 perfectly after delete and reboot.
I must say I am appalled because of the poor quality of drivers and the whole GMA950 hardware. When I bought my laptop I knew that the 945GM/GMA950 chipset was restricted performance and feature wise, but I never thought it would be downright broken.
SYSTEM: DELL XPS M1210 NOTEBOOK
OS: VISTA ULTIMATE 32BIT
PROBLEM: FLICKERING
SOLUTION: removing the registry string
This problem ocured after installing the newest drivers : 7.14.10.1283
So intel still didnt solve it. :( Realy bad thing...
BTW: i had this problem before, and the registry key was not there, so i could not fix it that way, i just reinstalled vista that time.
wow! next time try and restore your computer:) thats what i did and fixed the problem though it rolled back to the old drivers.
im trying to update to 15.4.3 but it gives me a error saying its not validated for this computer even thoughi have intel 945GM!! i think these drivers caused the flickering problem in the first place?
If i rfestore my system, i get WindowsXP (i just got this pc to use Vista on, becouse vista is running verry good on this thingy)
And how to update verry easy, extract the exe file you download from intel, en use the device manager to install the drivers withs you extracted from the exe file :)
Easy :)
I just installed Windows Vista Home Premium today. I'm using a silent PC buildt with these specs
Processor: Intel Core 2 Duo T5600 FSB667
Graphics: Intel GMA 945GM
TV card: Hauppauge Nova-T 500
HD: Samsung 400Gb and 500Gb
Ram: 2 Gb
Output: HDMI 1.2 to TV, using 1920x1080p at 60Hz
TV: Sharp 37" - LC37XD1E
The standard Vista installed works and I get a 1920x1080 resolution. I then tried to upgrade the Graphics driver to the latest version, but I'm really lost on the Intel site.
I tried to install a pack with winvista1523.exe and one with winvista1543.exe. Both had the nice effect that my flatscreen TV flickered with a black line running down over the picture at random intervals. So I reverted back using windows system restore screen back to the previous state without the flickering.
Where are the latest drivers? I found these links:
http://www.intel.com/support/chipsets/sb/CS-020683.htm
The table shows all sorts of 945.. something but not 945GM, should I just go with the 945GT instead?
If I go to
http://www.intel.com/support/graphics/intel945g/
takes me to a page for "82945G Express Chipset" hmm I was looking for 945GM. From that page and can get to this page
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2301
and from that I can get a link to this page
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2301&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version〈=eng&strOSs=153&submit=Go%21
that shows the drive as version 15.4 from 4/18/2007. The readme shows these details:
* Microsoft Windows Vista*
* Driver Revision: PV 15.4
* Package: 35087
* Graphics: 7.14.10.1255
* HDMI Audio: 6.10.0.2025
* April 18, 2007
* NOTE: This document refers to systems containing the
* following Intel chipsets:
* Intel 945G Express Chipset
* Intel 945GZ Express Chipset
* Intel 946GZ Express Chipset
* Intel G965 Express Chipset
* Intel Q963 Express Chipset
* Intel Q965 Express Chipset
* Mobile Intel 940GML Express Chipset
* Mobile Intel 943GML Express Chipset
* Mobile Intel 945GM Express Chipset
* Mobile Intel 945GMS Express Chipset
If I go with the 945GT link in the original table I can get to this page
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2102&OSFullName=Windows+Vista*+Home+Premium%2C+32-bit+version〈=eng&strOSs=153&submit=Go%21
that shows a drive with version 15.4.3 from 6/6/2007. The readme shows these details:
* Driver Revision: PV 15.4.3
* Package: 37610
* Graphics: 7.14.10.1283
* June 6, 2007
* Intel G33 Express Chipset
* Mobile Intel GM965 Express Chipset
The driver that shipped with Vista which I'm currently using is:
Driver Version: 7.14.0010.1138 (English)
DDI Version: 9Ex
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2006 01:00:30, 2105344 bytes
Driver Name: HdAudio.sys
Driver Version: 6.00.5840.16387 (English)
The reason I would like to upgrade the driver is that I have some problems with my Hauppauge Nova-t 500 TV card that records TV in Vista Media Center. Sometimes it works great and sometimes the recording stutters/jitters. I tought it would be a good idea to update all drivers to their latest version and see if that would help.
What 945GM driver should I download and install?
And are you using the exe file or the zip and just pointing the driver to update from within Devices?
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
