Software Archive
Read-only legacy content
17060 Discussions
Blank Hybrid Application with App Framework not working
Ryan_H_3
I was following the tutorial for page navigation.
So I created a blank hybrid application, and selected app framework.
I add a button and a blank page.
Then I select the page in interactivity for the button.
In the tutorial video is says there is a transition box that shows up, I get no such box.
Also, when I test the application in the emulator, clicking the button does nothing.
I've tried it about 4 times starting a new project...
HOWEVER... if I use a template project then it works fine.
I am to assume that the black project is broken?
I can't see any errors in the javascript console on testing...activate_page is being called on the button click, but does nothing.
Ryan_H_3
I replaced with af.ui.loadContent and it is working
The documentation is all over the place. what is .afui?
I can't figure out why sometimes $ works as a query selector, and other times it doesn't? Then I use af as the query selector and it seems to work?
The documentation says that app framework doesn't have a selector and to use jquery or fastclick. But I haven't referenced jquery or fastclick and it still seems to work sometimes?
I dunno... I'm finding this quite a saga to get started!
It seems so polished at first glance until you get into it....
