Software Archive
Read-only legacy content
17060 Discussions
std::condition_wait sometimes waits forever (and doesn't time out)
Mark_L_1
I've got code that works fine on our Xeon host system, but when it runs on our MICs, it hangs forever. I'm basically calling the C++ standard library "condition_variable::wait_for" with a timeout of 1000 milliseconds. The condition never becomes true, so this function should wait for 1000 ms and then return false. It works fine for a whileand prints out "timeout" every second, but after about 10 seconds, it just hangs entirely. However, if I "disturb" the MIC by either a key stroke (into a ssh session) or ping the MIC from the host, then it immediately "wakes up" and starts printing "timeout" again every second, but after another 10 seconds it hangs again.
     template< class Rep, class Period>
     bool wait(std::chrono::duration<Rep,Period> timeout)
         std::unique_lock<std::mutex> lock(mutex_);
         if (condition_.wait_for(lock, timeout) == std::cv_status::timeout)
                return false;
         return true;
Here's the calling loop
    while( wait(std::chrono::milliseconds(1000)))
         cout << "timeout" << endl;
It appears that the process is going to sleep. How do I prevent it from going to sleep? Do I need to change power management parameters? Is there a way of polling like this without hanging forever and using the default power management settings ?
Frances_R_Intel
As you say, you can disable power states to prevent the coprocessor from going to sleep. It may be sufficient to disable pc6, which requires a signal from the host before the coprocessor wakes up. However, it seems to me that the coprocessor should have set the C3WakeUpTimer and not gone into the pc6 state. I couldn't find any known problems, but if you will give me your host operating system version and the MPSS version you are running, I will try looking around some more.
Mark_L_1
pa-poca$ micinfo
MicInfo Utility Log
Created Tue Jun 16 16:17:21 2015
        System Info
                HOST OS                 : Linux
                OS Version              : 3.10.0-123.el7.x86_64
                Driver Version          : 3.5-1
                MPSS Version            : 3.5
                Host Physical Memory    : 263941 MB
Device No: 0, Device Name: mic0
        Version
                Flash Version            : 2.1.02.0391
                SMC Firmware Version     : 1.17.6900
                SMC Boot Loader Version  : 1.8.4326
                uOS Version              : 2.6.38.8+mpss3.5
                Device Serial Number     : ADKC32603169
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225c
                Subsystem ID             : 0x7d95
                Coprocessor Stepping ID  : 2
                PCIe Width               : Insufficient Privileges
                PCIe Speed               : Insufficient Privileges
                PCIe Max payload size    : Insufficient Privileges
                PCIe Max read req size   : Insufficient Privileges
                Coprocessor Model        : 0x01
                Coprocessor Model Ext    : 0x00
                Coprocessor Type         : 0x00
                Coprocessor Family       : 0x0b
                Coprocessor Family Ext   : 0x00
                Coprocessor Stepping     : C0
                Board SKU                : C0PRQ-7120 P/A/X/D
                ECC Mode                 : Enabled
                SMC HW Revision          : Product 300W Passive CS
        Cores
                Total No of Active Cores : 61
                Voltage                  : 1007000 uV
                Frequency                : 1238095 kHz
        Thermal
                Fan Speed Control        : N/A
                Fan RPM                  : N/A
                Fan PWM                  : N/A
                Die Temp                 : 56 C
        GDDR
                GDDR Vendor              : Samsung
                GDDR Version             : 0x6
                GDDR Density             : 4096 Mb
                GDDR Size                : 15872 MB
                GDDR Technology          : GDDR5
                GDDR Speed               : 5.500000 GT/s
                GDDR Frequency           : 2750000 kHz
                GDDR Voltage             : 1501000 uV
Device No: 1, Device Name: mic1
        Version
                Device Serial Number     : ADKC32603342
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225c
                ECC Mode                 : Enabled
        Cores
                Voltage                  : 998000 uV
        Thermal
                Fan RPM                  : N/A
                Fan PWM                  : N/A
                Die Temp                 : 56 C
        GDDR
                GDDR Version             : 0x6
Device No: 2, Device Name: mic2
        Version
                Device Serial Number     : ADKC32603243
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225c
                ECC Mode                 : Enabled
        Cores
                Voltage                  : 998000 uV
        Thermal
                Fan RPM                  : N/A
                Fan PWM                  : N/A
                Die Temp                 : 55 C
        GDDR
                GDDR Version             : 0x6
pa-poca$
