Software Archive
Read-only legacy content
Build ERROR!
Thomas_P_1
Can anyone tell me why I am getting the below error.  Says at the build notice to check my assets, but all assets are there and meet requirements.  Also, this build is an update, and the only update that has occurred does not involve the build assets or any core code (actually only update a misspelled word in the help file).  So why am I getting the below error found in the log.
.../TimeCaster/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: ant with args: release,-f,.../TimeCaster/platforms/android/build.xml,-Dout.dir=ant-build,-Dgen.absolute.dir=ant-gen
Command finished with error code 8: .../TimeCaster/platforms/android/cordova/build --release
Error: .../TimeCaster/platforms/android/cordova/build: Command failed with exit code 8
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
John_H_Intel2
There was an issue which has been fixed. Sorry for the delay in getting this resolved.
Try building your app again, if it does not succeed, please attach you entire log file.
Muthaiyan_R_
Hello Sir,   First i used Cordova CLI 4.1.2 , build works fine. After i upgraded to CLI to 5.1.1, below error showing, i don't have any idea why it happening. So please help me in this case. I have placed the build log below. ---
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.F4Gk_e.pl/org.apache.cordova.network-information"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.F4Gk_e.pl/org.apache.cordova.network-information" => ".../spvc/plugins/org.apache.cordova.network-information"
Calling plugman.install on plugin ".../spvc/plugins/org.apache.cordova.network-information" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.F4Gk_e.pl/org.apache.cordova.network-information":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.F4Gk_e.pl/org.apache.cordova.network-information/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.F4Gk_e.pl/org.apache.cordova.network-information","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.network-information","version":"0.2.14"},"text":"\n\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"Network Information","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Cordova Network Information Plugin","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,network,information","tail":"\n    ","_children":[]},{"_id":36,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-network-information.git","tail":"\n    ","_children":[]},{"_id":37,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320640","tail":"\n\n    ","_children":[]},{"_id":38,"tag":"js-module","attrib":{"src":"www/network.js","name":"network"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":39,"tag":"clobbers","attrib":{"target":"navigator.connection"},"text":"","tail":"\n        ","_children":[]},{"_id":40,"tag":"clobbers","attrib":{"target":"navigator.network.connection"},"text":"","tail":"\n    ","_children":[]}]},{"_id":41,"tag":"js-module","attrib":{"src":"www/Connection.js","name":"Connection"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":42,"tag":"clobbers","attrib":{"target":"Connection"},"text":"","tail":"\n    ","_children":[]}]},{"_id":43,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":44,"tag":"js-module","attrib":{"src":"src/firefoxos/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":45,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":46,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":47,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":48,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":49,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.networkinformation.NetworkManager"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":50,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":51,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":52,"tag":"source-file","attrib":{"src":"src/android/NetworkManager.java","target-dir":"src/org/apache/cordova/networkinformation"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":53,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n\n    \n    ","_children":[{"_id":54,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        \n        ","_children":[{"_id":55,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"   \n        ","_children":[{"_id":56,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.networkinformation.NetworkManager"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":57,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":58,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":59,"tag":"source-file","attrib":{"src":"src/android/NetworkManager.java","target-dir":"src/org/apache/cordova/networkinformation"},"text":"","tail":"\n        \n    ","_children":[]}]},{"_id":60,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":61,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":62,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":63,"tag":"param","attrib":{"policy_group":"connectivity","policy_version":"1"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":64,"tag":"header-file","attrib":{"src":"src/ubuntu/network_information.h"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ubuntu/network_information.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":66,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":68,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":69,"tag":"param","attrib":{"name":"ios-package","value":"CDVConnection"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":70,"tag":"header-file","attrib":{"src":"src/ios/CDVConnection.h"},"text":"","tail":"\n        ","_children":[]},{"_id":71,"tag":"source-file","attrib":{"src":"src/ios/CDVConnection.m"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"header-file","attrib":{"src":"src/ios/CDVReachability.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":73,"tag":"source-file","attrib":{"src":"src/ios/CDVReachability.m"},"text":"","tail":"\n\t    ","_children":[]},{"_id":74,"tag":"framework","attrib":{"src":"SystemConfiguration.framework","weak":"true"},"text":"","tail":"\n    ","_children":[]}]},{"_id":75,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":76,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"NetworkStatus"},"text":"","tail":"\n        ","_children":[]},{"_id":77,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":78,"tag":"feature","attrib":{"name":"NetworkStatus","value":"NetworkStatus"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":79,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":82,"tag":"param","attrib":{"name":"wp-package","value":"NetworkStatus"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":83,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":84,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":85,"tag":"source-file","attrib":{"src":"src/wp/NetworkStatus.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":86,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":87,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":88,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":89,"tag":"param","attrib":{"name":"wp-package","value":"NetworkStatus"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":90,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":91,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":92,"tag":"source-file","attrib":{"src":"src/wp/NetworkStatus.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":93,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":94,"tag":"js-module","attrib":{"src":"src/windows8/NetworkInfoProxy.js","name":"NetworkInfoProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":95,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":96,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":97,"tag":"js-module","attrib":{"src":"src/tizen/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":98,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":99,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":100,"tag":"js-module","attrib":{"src":"src/browser/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":101,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.network-information","version":"0.2.14","name":"Network Information","description":"Cordova Network Information Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-network-information.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320640","keywords":["cordova","network","information"]},".../spvc/plugins/org.apache.cordova.network-information":{"filepath":".../spvc/plugins/org.apache.cordova.network-information/plugin.xml","dir":".../spvc/plugins/org.apache.cordova.network-information","_et":{"_root":{"_id":102,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.network-information","version":"0.2.14"},"text":"\n\n    ","tail":null,"_children":[{"_id":103,"tag":"name","attrib":{},"text":"Network Information","tail":"\n    ","_children":[]},{"_id":104,"tag":"description","attrib":{},"text":"Cordova Network Information Plugin","tail":"\n    ","_children":[]},{"_id":105,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":106,"tag":"keywords","attrib":{},"text":"cordova,network,information","tail":"\n    ","_children":[]},{"_id":107,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-network-information.git","tail":"\n    ","_children":[]},{"_id":108,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320640","tail":"\n\n    ","_children":[]},{"_id":109,"tag":"js-module","attrib":{"src":"www/network.js","name":"network"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":110,"tag":"clobbers","attrib":{"target":"navigator.connection"},"text":"","tail":"\n        ","_children":[]},{"_id":111,"tag":"clobbers","attrib":{"target":"navigator.network.connection"},"text":"","tail":"\n    ","_children":[]}]},{"_id":112,"tag":"js-module","attrib":{"src":"www/Connection.js","name":"Connection"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":113,"tag":"clobbers","attrib":{"target":"Connection"},"text":"","tail":"\n    ","_children":[]}]},{"_id":114,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":115,"tag":"js-module","attrib":{"src":"src/firefoxos/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":116,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":117,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":118,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":119,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":120,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.networkinformation.NetworkManager"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":121,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":122,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":123,"tag":"source-file","attrib":{"src":"src/android/NetworkManager.java","target-dir":"src/org/apache/cordova/networkinformation"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":124,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n\n    \n    ","_children":[{"_id":125,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        \n        ","_children":[{"_id":126,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"   \n        ","_children":[{"_id":127,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.networkinformation.NetworkManager"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":128,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":129,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":130,"tag":"source-file","attrib":{"src":"src/android/NetworkManager.java","target-dir":"src/org/apache/cordova/networkinformation"},"text":"","tail":"\n        \n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":133,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":134,"tag":"param","attrib":{"policy_group":"connectivity","policy_version":"1"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":135,"tag":"header-file","attrib":{"src":"src/ubuntu/network_information.h"},"text":"","tail":"\n        ","_children":[]},{"_id":136,"tag":"source-file","attrib":{"src":"src/ubuntu/network_information.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":137,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":138,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":139,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":140,"tag":"param","attrib":{"name":"ios-package","value":"CDVConnection"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":141,"tag":"header-file","attrib":{"src":"src/ios/CDVConnection.h"},"text":"","tail":"\n        ","_children":[]},{"_id":142,"tag":"source-file","attrib":{"src":"src/ios/CDVConnection.m"},"text":"","tail":"\n        ","_children":[]},{"_id":143,"tag":"header-file","attrib":{"src":"src/ios/CDVReachability.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":144,"tag":"source-file","attrib":{"src":"src/ios/CDVReachability.m"},"text":"","tail":"\n\t    ","_children":[]},{"_id":145,"tag":"framework","attrib":{"src":"SystemConfiguration.framework","weak":"true"},"text":"","tail":"\n    ","_children":[]}]},{"_id":146,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":147,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"NetworkStatus"},"text":"","tail":"\n        ","_children":[]},{"_id":148,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":149,"tag":"feature","attrib":{"name":"NetworkStatus","value":"NetworkStatus"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":150,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":151,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":152,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":153,"tag":"param","attrib":{"name":"wp-package","value":"NetworkStatus"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":154,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":155,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":156,"tag":"source-file","attrib":{"src":"src/wp/NetworkStatus.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":157,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":158,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":159,"tag":"feature","attrib":{"name":"NetworkStatus"},"text":"\n                ","tail":"\n        ","_children":[{"_id":160,"tag":"param","attrib":{"name":"wp-package","value":"NetworkStatus"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":161,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":162,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":163,"tag":"source-file","attrib":{"src":"src/wp/NetworkStatus.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":164,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":165,"tag":"js-module","attrib":{"src":"src/windows8/NetworkInfoProxy.js","name":"NetworkInfoProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":166,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":167,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":168,"tag":"js-module","attrib":{"src":"src/tizen/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":169,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":170,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":171,"tag":"js-module","attrib":{"src":"src/browser/NetworkProxy.js","name":"NetworkProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":172,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.network-information","version":"0.2.14","name":"Network Information","description":"Cordova Network Information Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-network-information.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320640","keywords":["cordova","network","information"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "org.apache.cordova.network-information" for android
Running command: .../spvc/platforms/android/cordova/version
Command finished with error code 0: .../spvc/platforms/android/cordova/version
Install start for "org.apache.cordova.network-information" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'org.apache.cordova.network-information' ]
Writing out cordova_plugins.js...
Install complete for org.apache.cordova.network-information on android.
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.wIg58L.pl/org.apache.cordova.camera"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.wIg58L.pl/org.apache.cordova.camera" => ".../spvc/plugins/org.apache.cordova.camera"
Calling plugman.install on plugin ".../spvc/plugins/org.apache.cordova.camera" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.wIg58L.pl/org.apache.cordova.camera":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.wIg58L.pl/org.apache.cordova.camera/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.wIg58L.pl/org.apache.cordova.camera","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","xmlns:rim":"http://www.blackberry.com/ns/widgets","id":"org.apache.cordova.camera","version":"0.3.4"},"text":"\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"Camera","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Cordova Camera Plugin","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,camera","tail":"\n    ","_children":[]},{"_id":36,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-camera.git","tail":"\n    ","_children":[]},{"_id":37,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320645","tail":"\n\n    ","_children":[]},{"_id":38,"tag":"js-module","attrib":{"src":"www/CameraConstants.js","name":"Camera"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":39,"tag":"clobbers","attrib":{"target":"Camera"},"text":"","tail":"\n    ","_children":[]}]},{"_id":40,"tag":"js-module","attrib":{"src":"www/CameraPopoverOptions.js","name":"CameraPopoverOptions"},"text":"\n        ","tail":"\n\n\n\n    ","_children":[{"_id":41,"tag":"clobbers","attrib":{"target":"CameraPopoverOptions"},"text":"","tail":"\n    ","_children":[]}]},{"_id":42,"tag":"js-module","attrib":{"src":"www/Camera.js","name":"camera"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"clobbers","attrib":{"target":"navigator.camera"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"  \n\n    \n    ","_children":[{"_id":45,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"                                         \n        \n        ","_children":[{"_id":46,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":47,"tag":"param","attrib":{"name":"firefoxos-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":48,"tag":"js-module","attrib":{"src":"src/firefoxos/CameraProxy.js","name":"CameraProxy"},"text":"\n          ","tail":"\n    ","_children":[{"_id":49,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":50,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":51,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":52,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":53,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.camera.CameraLauncher"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":54,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":55,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/CameraLauncher.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":57,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"source-file","attrib":{"src":"src/android/ExifHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n\n        ","_children":[]},{"_id":59,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n     ","_children":[{"_id":60,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":61,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n     \n     \n     ","_children":[{"_id":62,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":63,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":64,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.camera.CameraLauncher"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":65,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":66,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":67,"tag":"source-file","attrib":{"src":"src/android/CameraLauncher.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":68,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":69,"tag":"source-file","attrib":{"src":"src/android/ExifHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n\n        ","_children":[]},{"_id":70,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n     ","_children":[{"_id":71,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":72,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n         ","tail":"\n\n     \n     ","_children":[{"_id":73,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n             ","tail":"\n         ","_children":[{"_id":74,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                 ","tail":"\n         ","_children":[{"_id":75,"tag":"param","attrib":{"policy_group":"camera","policy_version":"1"},"text":"","tail":"\n             ","_children":[]}]}]},{"_id":76,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n         ","_children":[{"_id":77,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n         ","_children":[]}]},{"_id":78,"tag":"header-file","attrib":{"src":"src/ubuntu/camera.h"},"text":"","tail":"\n         ","_children":[]},{"_id":79,"tag":"source-file","attrib":{"src":"src/ubuntu/camera.cpp"},"text":"","tail":"\n\n         ","_children":[]},{"_id":80,"tag":"resource-file","attrib":{"src":"src/ubuntu/back.png"},"text":"","tail":"\n         ","_children":[]},{"_id":81,"tag":"resource-file","attrib":{"src":"src/ubuntu/CaptureWidget.qml"},"text":"","tail":"\n         ","_children":[]},{"_id":82,"tag":"resource-file","attrib":{"src":"src/ubuntu/shoot.png"},"text":"","tail":"\n         ","_children":[]},{"_id":83,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-left.png"},"text":"","tail":"\n         ","_children":[]},{"_id":84,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-middle.png"},"text":"","tail":"\n         ","_children":[]},{"_id":85,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-right.png"},"text":"","tail":"\n     ","_children":[]}]},{"_id":86,"tag":"platform","attrib":{"name":"ios"},"text":"\n         ","tail":"\n\n    \n    ","_children":[{"_id":87,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n             ","tail":"\n\n         ","_children":[{"_id":88,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                 ","tail":"\n             ","_children":[{"_id":89,"tag":"param","attrib":{"name":"ios-package","value":"CDVCamera"},"text":"","tail":"\n             ","_children":[]}]},{"_id":90,"tag":"preference","attrib":{"name":"CameraUsesGeolocation","value":"false"},"text":"","tail":"\n         ","_children":[]}]},{"_id":91,"tag":"js-module","attrib":{"src":"www/ios/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n         ","_children":[{"_id":92,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n         ","_children":[]}]},{"_id":93,"tag":"header-file","attrib":{"src":"src/ios/CDVCamera.h"},"text":"","tail":"\n         ","_children":[]},{"_id":94,"tag":"source-file","attrib":{"src":"src/ios/CDVCamera.m"},"text":"","tail":"\n         ","_children":[]},{"_id":95,"tag":"header-file","attrib":{"src":"src/ios/CDVJpegHeaderWriter.h"},"text":"","tail":"\n         ","_children":[]},{"_id":96,"tag":"source-file","attrib":{"src":"src/ios/CDVJpegHeaderWriter.m"},"text":"","tail":"\n         ","_children":[]},{"_id":97,"tag":"header-file","attrib":{"src":"src/ios/CDVExif.h"},"text":"","tail":"\n         ","_children":[]},{"_id":98,"tag":"framework","attrib":{"src":"ImageIO.framework","weak":"true"},"text":"","tail":"\n         ","_children":[]},{"_id":99,"tag":"framework","attrib":{"src":"CoreLocation.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":100,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":101,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":102,"tag":"framework","attrib":{"src":"MobileCoreServices.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":103,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n         \n         ","_children":[]},{"_id":104,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"NSLocationWhenInUseUsageDescription"},"text":"\n             ","tail":"\n                  \n     ","_children":[{"_id":105,"tag":"string","attrib":{},"text":"","tail":"\n         ","_children":[]}]}]},{"_id":106,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n     \n    ","_children":[{"_id":107,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Camera"},"text":"","tail":"\n        ","_children":[]},{"_id":108,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":109,"tag":"feature","attrib":{"name":"Camera","value":"Camera"},"text":"","tail":"\n        ","_children":[]}]},{"_id":110,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n          ","tail":"\n        ","_children":[{"_id":111,"tag":"rim:permit","attrib":{},"text":"access_shared","tail":"\n          ","_children":[]},{"_id":112,"tag":"rim:permit","attrib":{},"text":"use_camera","tail":"\n        ","_children":[]}]},{"_id":113,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":114,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":115,"tag":"asset","attrib":{"src":"www/blackberry10/assets","target":"chrome"},"text":"","tail":"\n    ","_children":[]}]},{"_id":116,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":117,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":118,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":119,"tag":"param","attrib":{"name":"wp-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":120,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":121,"tag":"Capability","attrib":{"Name":"ID_CAP_ISV_CAMERA"},"text":"","tail":"\n            ","_children":[]},{"_id":122,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB"},"text":"","tail":"\n        ","_children":[]}]},{"_id":123,"tag":"source-file","attrib":{"src":"src/wp/Camera.cs"},"text":"","tail":"\n\n\n        ","_children":[]},{"_id":124,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n    ","_children":[{"_id":125,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":126,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":127,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":128,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":129,"tag":"param","attrib":{"name":"wp-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":130,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":131,"tag":"Capability","attrib":{"Name":"ID_CAP_ISV_CAMERA"},"text":"","tail":"\n            ","_children":[]},{"_id":132,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB_PHOTO"},"text":"","tail":"\n        ","_children":[]}]},{"_id":133,"tag":"source-file","attrib":{"src":"src/wp/Camera.cs"},"text":"","tail":"\n\n        ","_children":[]},{"_id":134,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n    ","_children":[{"_id":135,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":136,"tag":"platform","attrib":{"name":"windows8"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":137,"tag":"config-file","attrib":{"target":"package.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":138,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":139,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":140,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":141,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":142,"tag":"js-module","attrib":{"src":"src/windows/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":143,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":144,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":145,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":146,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":147,"tag":"param","attrib":{"name":"browser-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":148,"tag":"js-module","attrib":{"src":"src/browser/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":149,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":150,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n\n\n","_children":[{"_id":151,"tag":"config-file","attrib":{"target":"package.windows.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":152,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":153,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":154,"tag":"config-file","attrib":{"target":"package.windows80.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":155,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":156,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":157,"tag":"config-file","attrib":{"target":"package.phone.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":158,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":159,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":160,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":161,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":162,"tag":"js-module","attrib":{"src":"src/windows/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":163,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.camera","version":"0.3.4","name":"Camera","description":"Cordova Camera Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-camera.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320645","keywords":["cordova","camera"]},".../spvc/plugins/org.apache.cordova.camera":{"filepath":".../spvc/plugins/org.apache.cordova.camera/plugin.xml","dir":".../spvc/plugins/org.apache.cordova.camera","_et":{"_root":{"_id":164,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","xmlns:rim":"http://www.blackberry.com/ns/widgets","id":"org.apache.cordova.camera","version":"0.3.4"},"text":"\n    ","tail":null,"_children":[{"_id":165,"tag":"name","attrib":{},"text":"Camera","tail":"\n    ","_children":[]},{"_id":166,"tag":"description","attrib":{},"text":"Cordova Camera Plugin","tail":"\n    ","_children":[]},{"_id":167,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":168,"tag":"keywords","attrib":{},"text":"cordova,camera","tail":"\n    ","_children":[]},{"_id":169,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-camera.git","tail":"\n    ","_children":[]},{"_id":170,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320645","tail":"\n\n    ","_children":[]},{"_id":171,"tag":"js-module","attrib":{"src":"www/CameraConstants.js","name":"Camera"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":172,"tag":"clobbers","attrib":{"target":"Camera"},"text":"","tail":"\n    ","_children":[]}]},{"_id":173,"tag":"js-module","attrib":{"src":"www/CameraPopoverOptions.js","name":"CameraPopoverOptions"},"text":"\n        ","tail":"\n\n\n\n    ","_children":[{"_id":174,"tag":"clobbers","attrib":{"target":"CameraPopoverOptions"},"text":"","tail":"\n    ","_children":[]}]},{"_id":175,"tag":"js-module","attrib":{"src":"www/Camera.js","name":"camera"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":176,"tag":"clobbers","attrib":{"target":"navigator.camera"},"text":"","tail":"\n    ","_children":[]}]},{"_id":177,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"  \n\n    \n    ","_children":[{"_id":178,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"                                         \n        \n        ","_children":[{"_id":179,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":180,"tag":"param","attrib":{"name":"firefoxos-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":181,"tag":"js-module","attrib":{"src":"src/firefoxos/CameraProxy.js","name":"CameraProxy"},"text":"\n          ","tail":"\n    ","_children":[{"_id":182,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":183,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":184,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":185,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":186,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.camera.CameraLauncher"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":187,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":188,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":189,"tag":"source-file","attrib":{"src":"src/android/CameraLauncher.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":190,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":191,"tag":"source-file","attrib":{"src":"src/android/ExifHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n\n        ","_children":[]},{"_id":192,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n     ","_children":[{"_id":193,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":194,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n     \n     \n     ","_children":[{"_id":195,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":196,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":197,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.camera.CameraLauncher"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":198,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":199,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":200,"tag":"source-file","attrib":{"src":"src/android/CameraLauncher.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":201,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n        ","_children":[]},{"_id":202,"tag":"source-file","attrib":{"src":"src/android/ExifHelper.java","target-dir":"src/org/apache/cordova/camera"},"text":"","tail":"\n\n        ","_children":[]},{"_id":203,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n     ","_children":[{"_id":204,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":205,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n         ","tail":"\n\n     \n     ","_children":[{"_id":206,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n             ","tail":"\n         ","_children":[{"_id":207,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                 ","tail":"\n         ","_children":[{"_id":208,"tag":"param","attrib":{"policy_group":"camera","policy_version":"1"},"text":"","tail":"\n             ","_children":[]}]}]},{"_id":209,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n         ","_children":[{"_id":210,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n         ","_children":[]}]},{"_id":211,"tag":"header-file","attrib":{"src":"src/ubuntu/camera.h"},"text":"","tail":"\n         ","_children":[]},{"_id":212,"tag":"source-file","attrib":{"src":"src/ubuntu/camera.cpp"},"text":"","tail":"\n\n         ","_children":[]},{"_id":213,"tag":"resource-file","attrib":{"src":"src/ubuntu/back.png"},"text":"","tail":"\n         ","_children":[]},{"_id":214,"tag":"resource-file","attrib":{"src":"src/ubuntu/CaptureWidget.qml"},"text":"","tail":"\n         ","_children":[]},{"_id":215,"tag":"resource-file","attrib":{"src":"src/ubuntu/shoot.png"},"text":"","tail":"\n         ","_children":[]},{"_id":216,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-left.png"},"text":"","tail":"\n         ","_children":[]},{"_id":217,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-middle.png"},"text":"","tail":"\n         ","_children":[]},{"_id":218,"tag":"resource-file","attrib":{"src":"src/ubuntu/toolbar-right.png"},"text":"","tail":"\n     ","_children":[]}]},{"_id":219,"tag":"platform","attrib":{"name":"ios"},"text":"\n         ","tail":"\n\n    \n    ","_children":[{"_id":220,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n             ","tail":"\n\n         ","_children":[{"_id":221,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                 ","tail":"\n             ","_children":[{"_id":222,"tag":"param","attrib":{"name":"ios-package","value":"CDVCamera"},"text":"","tail":"\n             ","_children":[]}]},{"_id":223,"tag":"preference","attrib":{"name":"CameraUsesGeolocation","value":"false"},"text":"","tail":"\n         ","_children":[]}]},{"_id":224,"tag":"js-module","attrib":{"src":"www/ios/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n\n         ","_children":[{"_id":225,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n         ","_children":[]}]},{"_id":226,"tag":"header-file","attrib":{"src":"src/ios/CDVCamera.h"},"text":"","tail":"\n         ","_children":[]},{"_id":227,"tag":"source-file","attrib":{"src":"src/ios/CDVCamera.m"},"text":"","tail":"\n         ","_children":[]},{"_id":228,"tag":"header-file","attrib":{"src":"src/ios/CDVJpegHeaderWriter.h"},"text":"","tail":"\n         ","_children":[]},{"_id":229,"tag":"source-file","attrib":{"src":"src/ios/CDVJpegHeaderWriter.m"},"text":"","tail":"\n         ","_children":[]},{"_id":230,"tag":"header-file","attrib":{"src":"src/ios/CDVExif.h"},"text":"","tail":"\n         ","_children":[]},{"_id":231,"tag":"framework","attrib":{"src":"ImageIO.framework","weak":"true"},"text":"","tail":"\n         ","_children":[]},{"_id":232,"tag":"framework","attrib":{"src":"CoreLocation.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":233,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":234,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":235,"tag":"framework","attrib":{"src":"MobileCoreServices.framework"},"text":"","tail":"\n         ","_children":[]},{"_id":236,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n         \n         ","_children":[]},{"_id":237,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"NSLocationWhenInUseUsageDescription"},"text":"\n             ","tail":"\n                  \n     ","_children":[{"_id":238,"tag":"string","attrib":{},"text":"","tail":"\n         ","_children":[]}]}]},{"_id":239,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n     \n    ","_children":[{"_id":240,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Camera"},"text":"","tail":"\n        ","_children":[]},{"_id":241,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":242,"tag":"feature","attrib":{"name":"Camera","value":"Camera"},"text":"","tail":"\n        ","_children":[]}]},{"_id":243,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n          ","tail":"\n        ","_children":[{"_id":244,"tag":"rim:permit","attrib":{},"text":"access_shared","tail":"\n          ","_children":[]},{"_id":245,"tag":"rim:permit","attrib":{},"text":"use_camera","tail":"\n        ","_children":[]}]},{"_id":246,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":247,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":248,"tag":"asset","attrib":{"src":"www/blackberry10/assets","target":"chrome"},"text":"","tail":"\n    ","_children":[]}]},{"_id":249,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":250,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":251,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":252,"tag":"param","attrib":{"name":"wp-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":253,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":254,"tag":"Capability","attrib":{"Name":"ID_CAP_ISV_CAMERA"},"text":"","tail":"\n            ","_children":[]},{"_id":255,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB"},"text":"","tail":"\n        ","_children":[]}]},{"_id":256,"tag":"source-file","attrib":{"src":"src/wp/Camera.cs"},"text":"","tail":"\n\n\n        ","_children":[]},{"_id":257,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n    ","_children":[{"_id":258,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":259,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":260,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":261,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":262,"tag":"param","attrib":{"name":"wp-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":263,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":264,"tag":"Capability","attrib":{"Name":"ID_CAP_ISV_CAMERA"},"text":"","tail":"\n            ","_children":[]},{"_id":265,"tag":"Capability","attrib":{"Name":"ID_CAP_MEDIALIB_PHOTO"},"text":"","tail":"\n        ","_children":[]}]},{"_id":266,"tag":"source-file","attrib":{"src":"src/wp/Camera.cs"},"text":"","tail":"\n\n        ","_children":[]},{"_id":267,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n    ","_children":[{"_id":268,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":269,"tag":"platform","attrib":{"name":"windows8"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":270,"tag":"config-file","attrib":{"target":"package.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":271,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":272,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":273,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":274,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":275,"tag":"js-module","attrib":{"src":"src/windows/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":276,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":277,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":278,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":279,"tag":"feature","attrib":{"name":"Camera"},"text":"\n                ","tail":"\n        ","_children":[{"_id":280,"tag":"param","attrib":{"name":"browser-package","value":"Camera"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":281,"tag":"js-module","attrib":{"src":"src/browser/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":282,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":283,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n\n\n","_children":[{"_id":284,"tag":"config-file","attrib":{"target":"package.windows.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":285,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":286,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":287,"tag":"config-file","attrib":{"target":"package.windows80.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":288,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":289,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":290,"tag":"config-file","attrib":{"target":"package.phone.appxmanifest","parent":"/Package/Capabilities"},"text":"\n            ","tail":"\n        ","_children":[{"_id":291,"tag":"Capability","attrib":{"Name":"picturesLibrary"},"text":"","tail":"\n            ","_children":[]},{"_id":292,"tag":"DeviceCapability","attrib":{"Name":"webcam"},"text":"","tail":"\n        ","_children":[]}]},{"_id":293,"tag":"js-module","attrib":{"src":"www/CameraPopoverHandle.js","name":"CameraPopoverHandle"},"text":"\n            ","tail":"\n        ","_children":[{"_id":294,"tag":"clobbers","attrib":{"target":"CameraPopoverHandle"},"text":"","tail":"\n        ","_children":[]}]},{"_id":295,"tag":"js-module","attrib":{"src":"src/windows/CameraProxy.js","name":"CameraProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":296,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.camera","version":"0.3.4","name":"Camera","description":"Cordova Camera Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-camera.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320645","keywords":["cordova","camera"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "org.apache.cordova.camera" for android
Install start for "org.apache.cordova.camera" on android.
Iterating over installed plugins: [ 'org.apache.cordova.network-information',
  'org.apache.cordova.camera' ]
Install complete for org.apache.cordova.camera on android.
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.lSaTyf.pl/org.apache.cordova.file"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.lSaTyf.pl/org.apache.cordova.file" => ".../spvc/plugins/org.apache.cordova.file"
Calling plugman.install on plugin ".../spvc/plugins/org.apache.cordova.file" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.lSaTyf.pl/org.apache.cordova.file":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.lSaTyf.pl/org.apache.cordova.file/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.lSaTyf.pl/org.apache.cordova.file","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.file","version":"1.3.2"},"text":"\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"File","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Cordova File Plugin","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,file","tail":"\n    ","_children":[]},{"_id":36,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file.git","tail":"\n    ","_children":[]},{"_id":37,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320651","tail":"\n\n    ","_children":[]},{"_id":38,"tag":"js-module","attrib":{"src":"www/DirectoryEntry.js","name":"DirectoryEntry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":39,"tag":"clobbers","attrib":{"target":"window.DirectoryEntry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":40,"tag":"js-module","attrib":{"src":"www/DirectoryReader.js","name":"DirectoryReader"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":41,"tag":"clobbers","attrib":{"target":"window.DirectoryReader"},"text":"","tail":"\n    ","_children":[]}]},{"_id":42,"tag":"js-module","attrib":{"src":"www/Entry.js","name":"Entry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":43,"tag":"clobbers","attrib":{"target":"window.Entry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"js-module","attrib":{"src":"www/File.js","name":"File"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":45,"tag":"clobbers","attrib":{"target":"window.File"},"text":"","tail":"\n    ","_children":[]}]},{"_id":46,"tag":"js-module","attrib":{"src":"www/FileEntry.js","name":"FileEntry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":47,"tag":"clobbers","attrib":{"target":"window.FileEntry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":48,"tag":"js-module","attrib":{"src":"www/FileError.js","name":"FileError"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":49,"tag":"clobbers","attrib":{"target":"window.FileError"},"text":"","tail":"\n    ","_children":[]}]},{"_id":50,"tag":"js-module","attrib":{"src":"www/FileReader.js","name":"FileReader"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":51,"tag":"clobbers","attrib":{"target":"window.FileReader"},"text":"","tail":"\n    ","_children":[]}]},{"_id":52,"tag":"js-module","attrib":{"src":"www/FileSystem.js","name":"FileSystem"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":53,"tag":"clobbers","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n    ","_children":[]}]},{"_id":54,"tag":"js-module","attrib":{"src":"www/FileUploadOptions.js","name":"FileUploadOptions"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":55,"tag":"clobbers","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n    ","_children":[]}]},{"_id":56,"tag":"js-module","attrib":{"src":"www/FileUploadResult.js","name":"FileUploadResult"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":57,"tag":"clobbers","attrib":{"target":"window.FileUploadResult"},"text":"","tail":"\n    ","_children":[]}]},{"_id":58,"tag":"js-module","attrib":{"src":"www/FileWriter.js","name":"FileWriter"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":59,"tag":"clobbers","attrib":{"target":"window.FileWriter"},"text":"","tail":"\n    ","_children":[]}]},{"_id":60,"tag":"js-module","attrib":{"src":"www/Flags.js","name":"Flags"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":61,"tag":"clobbers","attrib":{"target":"window.Flags"},"text":"","tail":"\n    ","_children":[]}]},{"_id":62,"tag":"js-module","attrib":{"src":"www/LocalFileSystem.js","name":"LocalFileSystem"},"text":"\n        \n        ","tail":"\n\n    ","_children":[{"_id":63,"tag":"clobbers","attrib":{"target":"window.LocalFileSystem"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":64,"tag":"merges","attrib":{"target":"window"},"text":"","tail":"\n    ","_children":[]}]},{"_id":65,"tag":"js-module","attrib":{"src":"www/Metadata.js","name":"Metadata"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":66,"tag":"clobbers","attrib":{"target":"window.Metadata"},"text":"","tail":"\n    ","_children":[]}]},{"_id":67,"tag":"js-module","attrib":{"src":"www/ProgressEvent.js","name":"ProgressEvent"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":68,"tag":"clobbers","attrib":{"target":"window.ProgressEvent"},"text":"","tail":"\n    ","_children":[]}]},{"_id":69,"tag":"js-module","attrib":{"src":"www/fileSystems.js","name":"fileSystems"},"text":"","tail":"\n\n    ","_children":[]},{"_id":70,"tag":"js-module","attrib":{"src":"www/requestFileSystem.js","name":"requestFileSystem"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":71,"tag":"clobbers","attrib":{"target":"window.requestFileSystem"},"text":"","tail":"\n    ","_children":[]}]},{"_id":72,"tag":"js-module","attrib":{"src":"www/resolveLocalFileSystemURI.js","name":"resolveLocalFileSystemURI"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":73,"tag":"merges","attrib":{"target":"window"},"text":"","tail":"\n    ","_children":[]}]},{"_id":74,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":75,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":76,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":77,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.file.FileUtils"},"text":"","tail":"\n                ","_children":[]},{"_id":78,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":79,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":80,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":81,"tag":"source-file","attrib":{"src":"src/android/EncodingException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":82,"tag":"source-file","attrib":{"src":"src/android/FileExistsException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":83,"tag":"source-file","attrib":{"src":"src/android/InvalidModificationException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":84,"tag":"source-file","attrib":{"src":"src/android/NoModificationAllowedException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":85,"tag":"source-file","attrib":{"src":"src/android/TypeMismatchException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":86,"tag":"source-file","attrib":{"src":"src/android/FileUtils.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":87,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":88,"tag":"source-file","attrib":{"src":"src/android/DirectoryManager.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":89,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystemURL.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":90,"tag":"source-file","attrib":{"src":"src/android/Filesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":91,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":92,"tag":"source-file","attrib":{"src":"src/android/ContentFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":93,"tag":"js-module","attrib":{"src":"www/android/FileSystem.js","name":"androidFileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":94,"tag":"merges","attrib":{"target":"FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":95,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":96,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":97,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n    ","_children":[{"_id":98,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":99,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":100,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":101,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":102,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":103,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.file.FileUtils"},"text":"","tail":"\n                ","_children":[]},{"_id":104,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":105,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":106,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":107,"tag":"source-file","attrib":{"src":"src/android/EncodingException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":108,"tag":"source-file","attrib":{"src":"src/android/FileExistsException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":109,"tag":"source-file","attrib":{"src":"src/android/InvalidModificationException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":110,"tag":"source-file","attrib":{"src":"src/android/NoModificationAllowedException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":111,"tag":"source-file","attrib":{"src":"src/android/TypeMismatchException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":112,"tag":"source-file","attrib":{"src":"src/android/FileUtils.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":113,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":114,"tag":"source-file","attrib":{"src":"src/android/DirectoryManager.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":115,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystemURL.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":116,"tag":"source-file","attrib":{"src":"src/android/Filesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":117,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":118,"tag":"source-file","attrib":{"src":"src/android/ContentFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":119,"tag":"js-module","attrib":{"src":"www/android/FileSystem.js","name":"androidFileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":120,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":121,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":122,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":123,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n    ","_children":[{"_id":124,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":125,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":126,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":127,"tag":"header-file","attrib":{"src":"src/ubuntu/file.h"},"text":"","tail":"\n        ","_children":[]},{"_id":128,"tag":"source-file","attrib":{"src":"src/ubuntu/file.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":129,"tag":"js-module","attrib":{"src":"www/ubuntu/FileSystem.js","name":"ubuntuFileSystem1"},"text":"\n            ","tail":"\n        ","_children":[{"_id":130,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":131,"tag":"js-module","attrib":{"src":"www/ubuntu/FileWriter.js","name":"FileWriter1"},"text":"\n            ","tail":"\n        ","_children":[{"_id":132,"tag":"merges","attrib":{"target":"window.FileWriter"},"text":"","tail":"\n        ","_children":[]}]},{"_id":133,"tag":"js-module","attrib":{"src":"www/ubuntu/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n    ","_children":[{"_id":134,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":135,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":136,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":137,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":138,"tag":"param","attrib":{"name":"ios-package","value":"CDVFile"},"text":"","tail":"\n                ","_children":[]},{"_id":139,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":140,"tag":"header-file","attrib":{"src":"src/ios/CDVFile.h"},"text":"","tail":"\n        ","_children":[]},{"_id":141,"tag":"source-file","attrib":{"src":"src/ios/CDVFile.m"},"text":"","tail":"\n        ","_children":[]},{"_id":142,"tag":"header-file","attrib":{"src":"src/ios/CDVLocalFilesystem.h"},"text":"","tail":"\n        ","_children":[]},{"_id":143,"tag":"source-file","attrib":{"src":"src/ios/CDVLocalFilesystem.m"},"text":"","tail":"\n        ","_children":[]},{"_id":144,"tag":"header-file","attrib":{"src":"src/ios/CDVAssetLibraryFilesystem.h"},"text":"","tail":"\n        ","_children":[]},{"_id":145,"tag":"source-file","attrib":{"src":"src/ios/CDVAssetLibraryFilesystem.m"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":146,"tag":"js-module","attrib":{"src":"www/ios/FileSystem.js","name":"iosFileSystem"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":147,"tag":"merges","attrib":{"target":"FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":148,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":149,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":150,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":151,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":152,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":153,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n        ","_children":[]},{"_id":154,"tag":"framework","attrib":{"src":"MobileCoreServices.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":155,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":156,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":157,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":158,"tag":"param","attrib":{"name":"wp-package","value":"File"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":159,"tag":"source-file","attrib":{"src":"src/wp/File.cs"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":160,"tag":"js-module","attrib":{"src":"www/wp/FileUploadOptions.js","name":"FileUploadOptions1"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":161,"tag":"merges","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":162,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":163,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":164,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":165,"tag":"param","attrib":{"name":"wp-package","value":"File"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":166,"tag":"source-file","attrib":{"src":"src/wp/File.cs"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":167,"tag":"js-module","attrib":{"src":"www/wp/FileUploadOptions.js","name":"FileUploadOptions1"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":168,"tag":"merges","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":169,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":170,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":171,"tag":"feature","attrib":{"name":"File","value":"File"},"text":"","tail":"\n        ","_children":[]}]},{"_id":172,"tag":"js-module","attrib":{"src":"www/blackberry10/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":173,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":174,"tag":"js-module","attrib":{"src":"www/blackberry10/info.js","name":"bb10FileSystemInfo"},"text":"\n            ","tail":"\n        ","_children":[{"_id":175,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":176,"tag":"js-module","attrib":{"src":"www/blackberry10/createEntryFromNative.js","name":"bb10CreateEntryFromNative"},"text":"\n            ","tail":"\n        ","_children":[{"_id":177,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":178,"tag":"js-module","attrib":{"src":"www/blackberry10/requestAnimationFrame.js","name":"bb10RequestAnimationFrame"},"text":"\n            ","tail":"\n        ","_children":[{"_id":179,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":180,"tag":"js-module","attrib":{"src":"www/blackberry10/FileSystem.js","name":"bb10FileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":181,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":182,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":183,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":184,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n        ","_children":[{"_id":185,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n        ","_children":[]}]},{"_id":186,"tag":"js-module","attrib":{"src":"www/blackberry10/copyTo.js","name":"copyToProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":187,"tag":"js-module","attrib":{"src":"www/blackberry10/getDirectory.js","name":"getDirectoryProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":188,"tag":"js-module","attrib":{"src":"www/blackberry10/getFile.js","name":"getFileProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":189,"tag":"js-module","attrib":{"src":"www/blackberry10/getFileMetadata.js","name":"getFileMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":190,"tag":"js-module","attrib":{"src":"www/blackberry10/getMetadata.js","name":"getMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":191,"tag":"js-module","attrib":{"src":"www/blackberry10/getParent.js","name":"getParentProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":192,"tag":"js-module","attrib":{"src":"www/blackberry10/moveTo.js","name":"moveToProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":193,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsArrayBuffer.js","name":"readAsArrayBufferProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":194,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsBinaryString.js","name":"readAsBinaryStringProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":195,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsDataURL.js","name":"readAsDataURLProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":196,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsText.js","name":"readAsTextProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":197,"tag":"js-module","attrib":{"src":"www/blackberry10/readEntries.js","name":"readEntriesProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":198,"tag":"js-module","attrib":{"src":"www/blackberry10/remove.js","name":"removeProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":199,"tag":"js-module","attrib":{"src":"www/blackberry10/removeRecursively.js","name":"removeRecursivelyProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":200,"tag":"js-module","attrib":{"src":"www/blackberry10/resolveLocalFileSystemURI.js","name":"resolveLocalFileSystemURIProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":201,"tag":"js-module","attrib":{"src":"www/blackberry10/requestAllFileSystems.js","name":"requestAllFileSystemsProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":202,"tag":"js-module","attrib":{"src":"www/blackberry10/requestFileSystem.js","name":"requestFileSystemProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":203,"tag":"js-module","attrib":{"src":"www/blackberry10/setMetadata.js","name":"setMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":204,"tag":"js-module","attrib":{"src":"www/blackberry10/truncate.js","name":"truncateProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":205,"tag":"js-module","attrib":{"src":"www/blackberry10/write.js","name":"writeProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":206,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"File"},"text":"","tail":"\n    ","_children":[]}]},{"_id":207,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":208,"tag":"js-module","attrib":{"src":"src/windows/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":209,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":210,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":211,"tag":"js-module","attrib":{"src":"src/windows/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":212,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":213,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n","_children":[{"_id":214,"tag":"js-module","attrib":{"src":"src/firefoxos/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":215,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":216,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n\n        \n        ","_children":[{"_id":217,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":218,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":219,"tag":"js-module","attrib":{"src":"www/firefoxos/FileSystem.js","name":"firefoxFileSystem"},"text":"\n            ","tail":"\n    ","_children":[{"_id":220,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.file","version":"1.3.2","name":"File","description":"Cordova File Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320651","keywords":["cordova","file"]},".../spvc/plugins/org.apache.cordova.file":{"filepath":".../spvc/plugins/org.apache.cordova.file/plugin.xml","dir":".../spvc/plugins/org.apache.cordova.file","_et":{"_root":{"_id":221,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.file","version":"1.3.2"},"text":"\n    ","tail":null,"_children":[{"_id":222,"tag":"name","attrib":{},"text":"File","tail":"\n    ","_children":[]},{"_id":223,"tag":"description","attrib":{},"text":"Cordova File Plugin","tail":"\n    ","_children":[]},{"_id":224,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":225,"tag":"keywords","attrib":{},"text":"cordova,file","tail":"\n    ","_children":[]},{"_id":226,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file.git","tail":"\n    ","_children":[]},{"_id":227,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320651","tail":"\n\n    ","_children":[]},{"_id":228,"tag":"js-module","attrib":{"src":"www/DirectoryEntry.js","name":"DirectoryEntry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":229,"tag":"clobbers","attrib":{"target":"window.DirectoryEntry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":230,"tag":"js-module","attrib":{"src":"www/DirectoryReader.js","name":"DirectoryReader"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":231,"tag":"clobbers","attrib":{"target":"window.DirectoryReader"},"text":"","tail":"\n    ","_children":[]}]},{"_id":232,"tag":"js-module","attrib":{"src":"www/Entry.js","name":"Entry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":233,"tag":"clobbers","attrib":{"target":"window.Entry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":234,"tag":"js-module","attrib":{"src":"www/File.js","name":"File"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":235,"tag":"clobbers","attrib":{"target":"window.File"},"text":"","tail":"\n    ","_children":[]}]},{"_id":236,"tag":"js-module","attrib":{"src":"www/FileEntry.js","name":"FileEntry"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":237,"tag":"clobbers","attrib":{"target":"window.FileEntry"},"text":"","tail":"\n    ","_children":[]}]},{"_id":238,"tag":"js-module","attrib":{"src":"www/FileError.js","name":"FileError"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":239,"tag":"clobbers","attrib":{"target":"window.FileError"},"text":"","tail":"\n    ","_children":[]}]},{"_id":240,"tag":"js-module","attrib":{"src":"www/FileReader.js","name":"FileReader"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":241,"tag":"clobbers","attrib":{"target":"window.FileReader"},"text":"","tail":"\n    ","_children":[]}]},{"_id":242,"tag":"js-module","attrib":{"src":"www/FileSystem.js","name":"FileSystem"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":243,"tag":"clobbers","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n    ","_children":[]}]},{"_id":244,"tag":"js-module","attrib":{"src":"www/FileUploadOptions.js","name":"FileUploadOptions"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":245,"tag":"clobbers","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n    ","_children":[]}]},{"_id":246,"tag":"js-module","attrib":{"src":"www/FileUploadResult.js","name":"FileUploadResult"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":247,"tag":"clobbers","attrib":{"target":"window.FileUploadResult"},"text":"","tail":"\n    ","_children":[]}]},{"_id":248,"tag":"js-module","attrib":{"src":"www/FileWriter.js","name":"FileWriter"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":249,"tag":"clobbers","attrib":{"target":"window.FileWriter"},"text":"","tail":"\n    ","_children":[]}]},{"_id":250,"tag":"js-module","attrib":{"src":"www/Flags.js","name":"Flags"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":251,"tag":"clobbers","attrib":{"target":"window.Flags"},"text":"","tail":"\n    ","_children":[]}]},{"_id":252,"tag":"js-module","attrib":{"src":"www/LocalFileSystem.js","name":"LocalFileSystem"},"text":"\n        \n        ","tail":"\n\n    ","_children":[{"_id":253,"tag":"clobbers","attrib":{"target":"window.LocalFileSystem"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":254,"tag":"merges","attrib":{"target":"window"},"text":"","tail":"\n    ","_children":[]}]},{"_id":255,"tag":"js-module","attrib":{"src":"www/Metadata.js","name":"Metadata"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":256,"tag":"clobbers","attrib":{"target":"window.Metadata"},"text":"","tail":"\n    ","_children":[]}]},{"_id":257,"tag":"js-module","attrib":{"src":"www/ProgressEvent.js","name":"ProgressEvent"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":258,"tag":"clobbers","attrib":{"target":"window.ProgressEvent"},"text":"","tail":"\n    ","_children":[]}]},{"_id":259,"tag":"js-module","attrib":{"src":"www/fileSystems.js","name":"fileSystems"},"text":"","tail":"\n\n    ","_children":[]},{"_id":260,"tag":"js-module","attrib":{"src":"www/requestFileSystem.js","name":"requestFileSystem"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":261,"tag":"clobbers","attrib":{"target":"window.requestFileSystem"},"text":"","tail":"\n    ","_children":[]}]},{"_id":262,"tag":"js-module","attrib":{"src":"www/resolveLocalFileSystemURI.js","name":"resolveLocalFileSystemURI"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":263,"tag":"merges","attrib":{"target":"window"},"text":"","tail":"\n    ","_children":[]}]},{"_id":264,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":265,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":266,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":267,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.file.FileUtils"},"text":"","tail":"\n                ","_children":[]},{"_id":268,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":269,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":270,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":271,"tag":"source-file","attrib":{"src":"src/android/EncodingException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":272,"tag":"source-file","attrib":{"src":"src/android/FileExistsException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":273,"tag":"source-file","attrib":{"src":"src/android/InvalidModificationException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":274,"tag":"source-file","attrib":{"src":"src/android/NoModificationAllowedException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":275,"tag":"source-file","attrib":{"src":"src/android/TypeMismatchException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":276,"tag":"source-file","attrib":{"src":"src/android/FileUtils.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":277,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":278,"tag":"source-file","attrib":{"src":"src/android/DirectoryManager.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":279,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystemURL.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":280,"tag":"source-file","attrib":{"src":"src/android/Filesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":281,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":282,"tag":"source-file","attrib":{"src":"src/android/ContentFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":283,"tag":"js-module","attrib":{"src":"www/android/FileSystem.js","name":"androidFileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":284,"tag":"merges","attrib":{"target":"FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":285,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":286,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":287,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n    ","_children":[{"_id":288,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":289,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":290,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":291,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":292,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":293,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.file.FileUtils"},"text":"","tail":"\n                ","_children":[]},{"_id":294,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":295,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":296,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":297,"tag":"source-file","attrib":{"src":"src/android/EncodingException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":298,"tag":"source-file","attrib":{"src":"src/android/FileExistsException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":299,"tag":"source-file","attrib":{"src":"src/android/InvalidModificationException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":300,"tag":"source-file","attrib":{"src":"src/android/NoModificationAllowedException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":301,"tag":"source-file","attrib":{"src":"src/android/TypeMismatchException.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":302,"tag":"source-file","attrib":{"src":"src/android/FileUtils.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":303,"tag":"source-file","attrib":{"src":"src/android/FileHelper.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":304,"tag":"source-file","attrib":{"src":"src/android/DirectoryManager.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":305,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystemURL.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":306,"tag":"source-file","attrib":{"src":"src/android/Filesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":307,"tag":"source-file","attrib":{"src":"src/android/LocalFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        ","_children":[]},{"_id":308,"tag":"source-file","attrib":{"src":"src/android/ContentFilesystem.java","target-dir":"src/org/apache/cordova/file"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":309,"tag":"js-module","attrib":{"src":"www/android/FileSystem.js","name":"androidFileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":310,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":311,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":312,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":313,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n    ","_children":[{"_id":314,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":315,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":316,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":317,"tag":"header-file","attrib":{"src":"src/ubuntu/file.h"},"text":"","tail":"\n        ","_children":[]},{"_id":318,"tag":"source-file","attrib":{"src":"src/ubuntu/file.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":319,"tag":"js-module","attrib":{"src":"www/ubuntu/FileSystem.js","name":"ubuntuFileSystem1"},"text":"\n            ","tail":"\n        ","_children":[{"_id":320,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":321,"tag":"js-module","attrib":{"src":"www/ubuntu/FileWriter.js","name":"FileWriter1"},"text":"\n            ","tail":"\n        ","_children":[{"_id":322,"tag":"merges","attrib":{"target":"window.FileWriter"},"text":"","tail":"\n        ","_children":[]}]},{"_id":323,"tag":"js-module","attrib":{"src":"www/ubuntu/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n    ","_children":[{"_id":324,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":325,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":326,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":327,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":328,"tag":"param","attrib":{"name":"ios-package","value":"CDVFile"},"text":"","tail":"\n                ","_children":[]},{"_id":329,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":330,"tag":"header-file","attrib":{"src":"src/ios/CDVFile.h"},"text":"","tail":"\n        ","_children":[]},{"_id":331,"tag":"source-file","attrib":{"src":"src/ios/CDVFile.m"},"text":"","tail":"\n        ","_children":[]},{"_id":332,"tag":"header-file","attrib":{"src":"src/ios/CDVLocalFilesystem.h"},"text":"","tail":"\n        ","_children":[]},{"_id":333,"tag":"source-file","attrib":{"src":"src/ios/CDVLocalFilesystem.m"},"text":"","tail":"\n        ","_children":[]},{"_id":334,"tag":"header-file","attrib":{"src":"src/ios/CDVAssetLibraryFilesystem.h"},"text":"","tail":"\n        ","_children":[]},{"_id":335,"tag":"source-file","attrib":{"src":"src/ios/CDVAssetLibraryFilesystem.m"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":336,"tag":"js-module","attrib":{"src":"www/ios/FileSystem.js","name":"iosFileSystem"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":337,"tag":"merges","attrib":{"target":"FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":338,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":339,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":340,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":341,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":342,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":343,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n        ","_children":[]},{"_id":344,"tag":"framework","attrib":{"src":"MobileCoreServices.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":345,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":346,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":347,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":348,"tag":"param","attrib":{"name":"wp-package","value":"File"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":349,"tag":"source-file","attrib":{"src":"src/wp/File.cs"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":350,"tag":"js-module","attrib":{"src":"www/wp/FileUploadOptions.js","name":"FileUploadOptions1"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":351,"tag":"merges","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":352,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":353,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":354,"tag":"feature","attrib":{"name":"File"},"text":"\n                ","tail":"\n        ","_children":[{"_id":355,"tag":"param","attrib":{"name":"wp-package","value":"File"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":356,"tag":"source-file","attrib":{"src":"src/wp/File.cs"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":357,"tag":"js-module","attrib":{"src":"www/wp/FileUploadOptions.js","name":"FileUploadOptions1"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":358,"tag":"merges","attrib":{"target":"window.FileUploadOptions"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":359,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":360,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":361,"tag":"feature","attrib":{"name":"File","value":"File"},"text":"","tail":"\n        ","_children":[]}]},{"_id":362,"tag":"js-module","attrib":{"src":"www/blackberry10/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":363,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":364,"tag":"js-module","attrib":{"src":"www/blackberry10/info.js","name":"bb10FileSystemInfo"},"text":"\n            ","tail":"\n        ","_children":[{"_id":365,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":366,"tag":"js-module","attrib":{"src":"www/blackberry10/createEntryFromNative.js","name":"bb10CreateEntryFromNative"},"text":"\n            ","tail":"\n        ","_children":[{"_id":367,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":368,"tag":"js-module","attrib":{"src":"www/blackberry10/requestAnimationFrame.js","name":"bb10RequestAnimationFrame"},"text":"\n            ","tail":"\n        ","_children":[{"_id":369,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":370,"tag":"js-module","attrib":{"src":"www/blackberry10/FileSystem.js","name":"bb10FileSystem"},"text":"\n            ","tail":"\n        ","_children":[{"_id":371,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]},{"_id":372,"tag":"js-module","attrib":{"src":"www/fileSystems-roots.js","name":"fileSystems-roots"},"text":"\n            ","tail":"\n        ","_children":[{"_id":373,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":374,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n        ","_children":[{"_id":375,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n        ","_children":[]}]},{"_id":376,"tag":"js-module","attrib":{"src":"www/blackberry10/copyTo.js","name":"copyToProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":377,"tag":"js-module","attrib":{"src":"www/blackberry10/getDirectory.js","name":"getDirectoryProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":378,"tag":"js-module","attrib":{"src":"www/blackberry10/getFile.js","name":"getFileProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":379,"tag":"js-module","attrib":{"src":"www/blackberry10/getFileMetadata.js","name":"getFileMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":380,"tag":"js-module","attrib":{"src":"www/blackberry10/getMetadata.js","name":"getMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":381,"tag":"js-module","attrib":{"src":"www/blackberry10/getParent.js","name":"getParentProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":382,"tag":"js-module","attrib":{"src":"www/blackberry10/moveTo.js","name":"moveToProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":383,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsArrayBuffer.js","name":"readAsArrayBufferProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":384,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsBinaryString.js","name":"readAsBinaryStringProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":385,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsDataURL.js","name":"readAsDataURLProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":386,"tag":"js-module","attrib":{"src":"www/blackberry10/readAsText.js","name":"readAsTextProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":387,"tag":"js-module","attrib":{"src":"www/blackberry10/readEntries.js","name":"readEntriesProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":388,"tag":"js-module","attrib":{"src":"www/blackberry10/remove.js","name":"removeProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":389,"tag":"js-module","attrib":{"src":"www/blackberry10/removeRecursively.js","name":"removeRecursivelyProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":390,"tag":"js-module","attrib":{"src":"www/blackberry10/resolveLocalFileSystemURI.js","name":"resolveLocalFileSystemURIProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":391,"tag":"js-module","attrib":{"src":"www/blackberry10/requestAllFileSystems.js","name":"requestAllFileSystemsProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":392,"tag":"js-module","attrib":{"src":"www/blackberry10/requestFileSystem.js","name":"requestFileSystemProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":393,"tag":"js-module","attrib":{"src":"www/blackberry10/setMetadata.js","name":"setMetadataProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":394,"tag":"js-module","attrib":{"src":"www/blackberry10/truncate.js","name":"truncateProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":395,"tag":"js-module","attrib":{"src":"www/blackberry10/write.js","name":"writeProxy"},"text":"","tail":"\n        ","_children":[]},{"_id":396,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"File"},"text":"","tail":"\n    ","_children":[]}]},{"_id":397,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":398,"tag":"js-module","attrib":{"src":"src/windows/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":399,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":400,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":401,"tag":"js-module","attrib":{"src":"src/windows/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":402,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":403,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n","_children":[{"_id":404,"tag":"js-module","attrib":{"src":"src/firefoxos/FileProxy.js","name":"FileProxy"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":405,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":406,"tag":"js-module","attrib":{"src":"www/fileSystemPaths.js","name":"fileSystemPaths"},"text":"\n            ","tail":"\n\n        \n        ","_children":[{"_id":407,"tag":"merges","attrib":{"target":"cordova"},"text":"","tail":"\n            ","_children":[]},{"_id":408,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":409,"tag":"js-module","attrib":{"src":"www/firefoxos/FileSystem.js","name":"firefoxFileSystem"},"text":"\n            ","tail":"\n    ","_children":[{"_id":410,"tag":"merges","attrib":{"target":"window.FileSystem"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.file","version":"1.3.2","name":"File","description":"Cordova File Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320651","keywords":["cordova","file"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "org.apache.cordova.file" for android
Running command: .../spvc/platforms/android/cordova/version
Command finished with error code 0: .../spvc/platforms/android/cordova/version
Install start for "org.apache.cordova.file" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
  'org.apache.cordova.camera',
  'org.apache.cordova.file' ]
Writing out cordova_plugins.js...
Install complete for org.apache.cordova.file on android.
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.gsk5Kj.pl/org.apache.cordova.file-transfer"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.gsk5Kj.pl/org.apache.cordova.file-transfer" => ".../spvc/plugins/org.apache.cordova.file-transfer"
Calling plugman.install on plugin ".../spvc/plugins/org.apache.cordova.file-transfer" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.gsk5Kj.pl/org.apache.cordova.file-transfer":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.gsk5Kj.pl/org.apache.cordova.file-transfer/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.gsk5Kj.pl/org.apache.cordova.file-transfer","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.file-transfer","version":"0.4.8"},"text":"\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"File Transfer","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Cordova File Transfer Plugin","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,file,transfer","tail":"\n    ","_children":[]},{"_id":36,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file-transfer.git","tail":"\n    ","_children":[]},{"_id":37,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320650","tail":"\n\n    \n    ","_children":[]},{"_id":38,"tag":"dependency","attrib":{"id":"org.apache.cordova.file","version":">=1.0.1"},"text":"","tail":"\n\n    ","_children":[]},{"_id":39,"tag":"js-module","attrib":{"src":"www/FileTransferError.js","name":"FileTransferError"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":40,"tag":"clobbers","attrib":{"target":"window.FileTransferError"},"text":"","tail":"\n    ","_children":[]}]},{"_id":41,"tag":"js-module","attrib":{"src":"www/FileTransfer.js","name":"FileTransfer"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":42,"tag":"clobbers","attrib":{"target":"window.FileTransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":43,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":44,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":45,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":46,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.filetransfer.FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":47,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":48,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":49,"tag":"source-file","attrib":{"src":"src/android/FileTransfer.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":50,"tag":"source-file","attrib":{"src":"src/android/FileProgressResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":51,"tag":"source-file","attrib":{"src":"src/android/FileUploadResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":52,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":53,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":54,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":55,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.filetransfer.FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":56,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":57,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":58,"tag":"source-file","attrib":{"src":"src/amazon/FileTransfer.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"src/android/FileProgressResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":60,"tag":"source-file","attrib":{"src":"src/android/FileUploadResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":61,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":62,"tag":"header-file","attrib":{"src":"src/ubuntu/file-transfer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/ubuntu/file-transfer.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":64,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":65,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":66,"tag":"feature","attrib":{"name":"FileTransfer","value":"FileTransfer"},"text":"","tail":"\n        ","_children":[]}]},{"_id":67,"tag":"js-module","attrib":{"src":"www/blackberry10/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":68,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":69,"tag":"js-module","attrib":{"src":"www/blackberry10/xhrFileTransfer.js","name":"xhrFileTransfer"},"text":"","tail":"\n        \n    ","_children":[]}]},{"_id":70,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":71,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":72,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":73,"tag":"param","attrib":{"name":"ios-package","value":"CDVFileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":74,"tag":"header-file","attrib":{"src":"src/ios/CDVFileTransfer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":75,"tag":"source-file","attrib":{"src":"src/ios/CDVFileTransfer.m"},"text":"","tail":"\n\n        ","_children":[]},{"_id":76,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":77,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":78,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":79,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":80,"tag":"param","attrib":{"name":"wp-package","value":"FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":81,"tag":"source-file","attrib":{"src":"src/wp/FileTransfer.cs"},"text":"","tail":"\n\n        ","_children":[]},{"_id":82,"tag":"js-module","attrib":{"src":"www/wp7/base64.js","name":"base64"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":83,"tag":"clobbers","attrib":{"target":"window.FileTransferBase64"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":84,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":85,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":86,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":87,"tag":"param","attrib":{"name":"wp-package","value":"FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":88,"tag":"source-file","attrib":{"src":"src/wp/FileTransfer.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":89,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":90,"tag":"js-module","attrib":{"src":"src/windows/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":91,"tag":"clobbers","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":92,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":93,"tag":"js-module","attrib":{"src":"src/windows/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":94,"tag":"clobbers","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":95,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n","_children":[{"_id":96,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":97,"tag":"permission","attrib":{"name":"systemXHR","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":98,"tag":"js-module","attrib":{"src":"www/firefoxos/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":99,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.file-transfer","version":"0.4.8","name":"File Transfer","description":"Cordova File Transfer Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file-transfer.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320650","keywords":["cordova","file","transfer"]},".../spvc/plugins/org.apache.cordova.file-transfer":{"filepath":".../spvc/plugins/org.apache.cordova.file-transfer/plugin.xml","dir":".../spvc/plugins/org.apache.cordova.file-transfer","_et":{"_root":{"_id":100,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"org.apache.cordova.file-transfer","version":"0.4.8"},"text":"\n    ","tail":null,"_children":[{"_id":101,"tag":"name","attrib":{},"text":"File Transfer","tail":"\n    ","_children":[]},{"_id":102,"tag":"description","attrib":{},"text":"Cordova File Transfer Plugin","tail":"\n    ","_children":[]},{"_id":103,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":104,"tag":"keywords","attrib":{},"text":"cordova,file,transfer","tail":"\n    ","_children":[]},{"_id":105,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file-transfer.git","tail":"\n    ","_children":[]},{"_id":106,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320650","tail":"\n\n    \n    ","_children":[]},{"_id":107,"tag":"dependency","attrib":{"id":"org.apache.cordova.file","version":">=1.0.1"},"text":"","tail":"\n\n    ","_children":[]},{"_id":108,"tag":"js-module","attrib":{"src":"www/FileTransferError.js","name":"FileTransferError"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":109,"tag":"clobbers","attrib":{"target":"window.FileTransferError"},"text":"","tail":"\n    ","_children":[]}]},{"_id":110,"tag":"js-module","attrib":{"src":"www/FileTransfer.js","name":"FileTransfer"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"clobbers","attrib":{"target":"window.FileTransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":112,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":113,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":114,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":115,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.filetransfer.FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":116,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":117,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":118,"tag":"source-file","attrib":{"src":"src/android/FileTransfer.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":119,"tag":"source-file","attrib":{"src":"src/android/FileProgressResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":120,"tag":"source-file","attrib":{"src":"src/android/FileUploadResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":121,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":122,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":123,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":124,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.filetransfer.FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":125,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":126,"tag":"uses-permission","attrib":{"android:name":"android.permission.WRITE_EXTERNAL_STORAGE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":127,"tag":"source-file","attrib":{"src":"src/amazon/FileTransfer.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":128,"tag":"source-file","attrib":{"src":"src/android/FileProgressResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n        ","_children":[]},{"_id":129,"tag":"source-file","attrib":{"src":"src/android/FileUploadResult.java","target-dir":"src/org/apache/cordova/filetransfer"},"text":"","tail":"\n    ","_children":[]}]},{"_id":130,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":131,"tag":"header-file","attrib":{"src":"src/ubuntu/file-transfer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":132,"tag":"source-file","attrib":{"src":"src/ubuntu/file-transfer.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":133,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":134,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":135,"tag":"feature","attrib":{"name":"FileTransfer","value":"FileTransfer"},"text":"","tail":"\n        ","_children":[]}]},{"_id":136,"tag":"js-module","attrib":{"src":"www/blackberry10/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n        ","_children":[{"_id":137,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]},{"_id":138,"tag":"js-module","attrib":{"src":"www/blackberry10/xhrFileTransfer.js","name":"xhrFileTransfer"},"text":"","tail":"\n        \n    ","_children":[]}]},{"_id":139,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":140,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":141,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":142,"tag":"param","attrib":{"name":"ios-package","value":"CDVFileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":143,"tag":"header-file","attrib":{"src":"src/ios/CDVFileTransfer.h"},"text":"","tail":"\n        ","_children":[]},{"_id":144,"tag":"source-file","attrib":{"src":"src/ios/CDVFileTransfer.m"},"text":"","tail":"\n\n        ","_children":[]},{"_id":145,"tag":"framework","attrib":{"src":"AssetsLibrary.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":146,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":147,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":148,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":149,"tag":"param","attrib":{"name":"wp-package","value":"FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":150,"tag":"source-file","attrib":{"src":"src/wp/FileTransfer.cs"},"text":"","tail":"\n\n        ","_children":[]},{"_id":151,"tag":"js-module","attrib":{"src":"www/wp7/base64.js","name":"base64"},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":152,"tag":"clobbers","attrib":{"target":"window.FileTransferBase64"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":153,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":154,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":155,"tag":"feature","attrib":{"name":"FileTransfer"},"text":"\n                ","tail":"\n        ","_children":[{"_id":156,"tag":"param","attrib":{"name":"wp-package","value":"FileTransfer"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":157,"tag":"source-file","attrib":{"src":"src/wp/FileTransfer.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":158,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":159,"tag":"js-module","attrib":{"src":"src/windows/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":160,"tag":"clobbers","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":161,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":162,"tag":"js-module","attrib":{"src":"src/windows/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":163,"tag":"clobbers","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":164,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n","_children":[{"_id":165,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":166,"tag":"permission","attrib":{"name":"systemXHR","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":167,"tag":"js-module","attrib":{"src":"www/firefoxos/FileTransferProxy.js","name":"FileTransferProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":168,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.file-transfer","version":"0.4.8","name":"File Transfer","description":"Cordova File Transfer Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-file-transfer.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320650","keywords":["cordova","file","transfer"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "org.apache.cordova.file-transfer" for android
Dependencies detected, iterating through them...
Dependent plugin "org.apache.cordova.file" already fetched, using that version.
Dependent plugin "org.apache.cordova.file" already installed on android.
Install start for "org.apache.cordova.file-transfer" on android.
Iterating over installed plugins: [ 'org.apache.cordova.network-information',
  'org.apache.cordova.file',
  'org.apache.cordova.file-transfer' ]
Install complete for org.apache.cordova.file-transfer on android.
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.jQmW7H.pl/cordova-plugin-legacy-whitelist"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.jQmW7H.pl/cordova-plugin-legacy-whitelist" => ".../spvc/plugins/cordova-plugin-legacy-whitelist"
Calling plugman.install on plugin ".../spvc/plugins/cordova-plugin-legacy-whitelist" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.jQmW7H.pl/cordova-plugin-legacy-whitelist":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.jQmW7H.pl/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.jQmW7H.pl/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":36,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":37,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":38,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":39,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":40,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":41,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]},".../spvc/plugins/cordova-plugin-legacy-whitelist":{"filepath":".../spvc/plugins/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../spvc/plugins/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":42,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":43,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":44,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":45,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":46,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":47,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":48,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":49,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":50,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":51,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":52,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-legacy-whitelist" for android
Install start for "cordova-plugin-legacy-whitelist" on android.
  'org.apache.cordova.file-transfer',
  'cordova-plugin-legacy-whitelist' ]
Install complete for cordova-plugin-legacy-whitelist on android.
Calling plugman.fetch on plugin ".../cachedPlugins.rQ9TPB.tmp/cache.Ssg8Ow.pl/cordova-plugin-crosswalk-webview"
Copying plugin ".../cachedPlugins.rQ9TPB.tmp/cache.Ssg8Ow.pl/cordova-plugin-crosswalk-webview" => ".../spvc/plugins/cordova-plugin-crosswalk-webview"
Calling plugman.install on plugin ".../spvc/plugins/cordova-plugin-crosswalk-webview" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.rQ9TPB.tmp/cache.Ssg8Ow.pl/cordova-plugin-crosswalk-webview":{"filepath":".../cachedPlugins.rQ9TPB.tmp/cache.Ssg8Ow.pl/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../cachedPlugins.rQ9TPB.tmp/cache.Ssg8Ow.pl/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":32,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":33,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":34,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":35,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":36,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":37,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":38,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":39,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":40,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":41,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":42,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":43,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":44,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":45,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":46,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":47,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":48,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":49,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":50,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":51,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":52,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":53,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":54,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":55,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":56,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":57,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]},".../spvc/plugins/cordova-plugin-crosswalk-webview":{"filepath":".../spvc/plugins/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../spvc/plugins/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":59,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":60,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":61,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":62,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":63,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":64,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":65,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":66,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":68,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":69,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":70,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":71,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":72,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":73,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":74,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":75,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":76,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":77,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":78,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":79,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":80,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":81,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":82,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":83,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":84,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":85,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":86,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-crosswalk-webview" for android
Install start for "cordova-plugin-crosswalk-webview" on android.
Installing Android library: platforms/android/xwalk.gradle
  'cordova-plugin-legacy-whitelist',
  'cordova-plugin-crosswalk-webview' ]
Install complete for cordova-plugin-crosswalk-webview on android.
Updating build files since android plugin contained <framework>
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
Wrote out Android application name to "Subramaniyapuram Vellan Chettiyar Official App"
deleted: .../spvc/platforms/android/res/drawable-land-hdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-land-ldpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-land-mdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-land-xhdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-port-hdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-port-ldpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-port-mdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-port-xhdpi/screen.png
splash screens: [{"src":"www/images/splashscreen/splashscreen_320X426.jpg","density":"port-ldpi","platform":null,"width":320,"height":426},{"src":"www/images/splashscreen/splashscreen_320X470.jpg","density":"port-mdpi","platform":null,"width":320,"height":470},{"src":"www/images/splashscreen/splashscreen_480X640.jpg","density":"port-hdpi","platform":null,"width":480,"height":640},{"src":"www/images/splashscreen/splashscreen_720X960.jpg","density":"port-xhdpi","platform":null,"width":720,"height":960}]
copying image from .../spvc/www/images/splashscreen/splashscreen_320X426.jpg to .../spvc/platforms/android/res/drawable-port-ldpi/screen.png
copying image from .../spvc/www/images/splashscreen/splashscreen_320X470.jpg to .../spvc/platforms/android/res/drawable-port-mdpi/screen.png
copying image from .../spvc/www/images/splashscreen/splashscreen_480X640.jpg to .../spvc/platforms/android/res/drawable-port-hdpi/screen.png
copying image from .../spvc/www/images/splashscreen/splashscreen_720X960.jpg to .../spvc/platforms/android/res/drawable-port-xhdpi/screen.png
deleted: .../spvc/platforms/android/res/drawable-hdpi/icon.png
deleted: .../spvc/platforms/android/res/drawable-ldpi/icon.png
deleted: .../spvc/platforms/android/res/drawable-mdpi/icon.png
deleted: .../spvc/platforms/android/res/drawable-xhdpi/icon.png
copying image from .../spvc/www/images/icons/ic_launcher_36x36.png to .../spvc/platforms/android/res/drawable-ldpi/icon.png
copying image from .../spvc/www/images/icons/ic_launcher_48x48.png to .../spvc/platforms/android/res/drawable-mdpi/icon.png
copying image from .../spvc/www/images/icons/ic_launcher_72x72.png to .../spvc/platforms/android/res/drawable-hdpi/icon.png
copying image from .../spvc/www/images/icons/ic_launcher_96x96.png to .../spvc/platforms/android/res/drawable-xhdpi/icon.png
Wrote out Android package name to "com.spm.vellanchettiyar"
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../spvc]
Will process and update the following config files:
    Config.xml = [.../spvc/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Subramaniyapuram Vellan Chettiyar Official App]
Updating full app name to [Subramaniyapuram Vellan Chettiyar Official App]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Found permission [ACCESS_NETWORK_STATE]
Found permission [ACCESS_WIFI_STATE]
Processing preference permissions
Found existing permission [android.permission.ACCESS_NETWORK_STATE]
Found existing permission [android.permission.ACCESS_WIFI_STATE]
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../spvc/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../spvc/platforms/android/cordova/build --release
ANDROID_HOME=/Developer/android-sdk-linux
JAVA_HOME=/usr/lib/jvm/java-7-oracle
Running: .../spvc/platforms/android/gradlew cdvBuildRelease -b .../spvc/platforms/android/build.gradle -Dorg.gradle.daemon=true
embedded
WARNING [Project: :] Current NDK support is deprecated.  Alternative will be provided in the future.
org.xwalk:xwalk_core_library_beta:15+
:preBuild
:compileArmv7ReleaseNdk
:preArmv7ReleaseBuild
:checkArmv7ReleaseManifest
:preX86ReleaseBuild
:CordovaLib:compileLint
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:mergeReleaseProguardFiles
:CordovaLib:preBuild
:CordovaLib:preReleaseBuild
:CordovaLib:checkReleaseManifest
:CordovaLib:prepareReleaseDependencies
:CordovaLib:compileReleaseAidl
:CordovaLib:compileReleaseRenderscript
:CordovaLib:generateReleaseBuildConfig
:CordovaLib:generateReleaseAssets UP-TO-DATE
:CordovaLib:mergeReleaseAssets
:CordovaLib:generateReleaseResValues
:CordovaLib:generateReleaseResources
:CordovaLib:packageReleaseResources
:CordovaLib:processReleaseManifest
:CordovaLib:processReleaseResources
:CordovaLib:generateReleaseSources
:CordovaLib:compileReleaseJavaNote: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:packageReleaseJar
:CordovaLib:compileReleaseNdk
:CordovaLib:packageReleaseJniLibs UP-TO-DATE
:CordovaLib:packageReleaseLocalJar UP-TO-DATE
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:bundleRelease
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary
:preArmv7DebugBuild
:preX86DebugBuild
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:mergeDebugProguardFiles
:CordovaLib:preDebugBuild
:CordovaLib:checkDebugManifest
:CordovaLib:prepareDebugDependencies
:CordovaLib:compileDebugAidl
:CordovaLib:compileDebugRenderscript
:CordovaLib:generateDebugBuildConfig
:CordovaLib:generateDebugAssets UP-TO-DATE
:CordovaLib:mergeDebugAssets
:CordovaLib:generateDebugResValues
:CordovaLib:generateDebugResources
:CordovaLib:packageDebugResources
:CordovaLib:processDebugManifest
:CordovaLib:processDebugResources
:CordovaLib:generateDebugSources
:CordovaLib:compileDebugJavaNote: Some input files use or override a deprecated API.
:CordovaLib:processDebugJavaRes UP-TO-DATE
:CordovaLib:packageDebugJar
:CordovaLib:compileDebugNdk
:CordovaLib:packageDebugJniLibs UP-TO-DATE
:CordovaLib:packageDebugLocalJar UP-TO-DATE
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:bundleDebug
:prepareOrgXwalkXwalk_core_library_beta154438412Library
:prepareArmv7ReleaseDependencies
:compileArmv7ReleaseAidl
:compileArmv7ReleaseRenderscript
:generateArmv7ReleaseBuildConfig
:generateArmv7ReleaseAssets UP-TO-DATE
:mergeArmv7ReleaseAssets
:createXwalkCommandLineFileArmv7Release
:generateArmv7ReleaseResValues
:generateArmv7ReleaseResources
:mergeArmv7ReleaseResourceslibpng error: Not a PNG file
Error: Failed to run command:
	/Developer/android-sdk-linux/build-tools/22.0.1/aapt s -i .../spvc/platforms/android/res/drawable-port-ldpi/screen.png -o .../spvc/platforms/android/build/intermediates/res/armv7/release/drawable-port-ldpi-v4/screen.png
Error Code:
	42
Output:
:mergeArmv7ReleaseResources FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':mergeArmv7ReleaseResources'.
  Error Code:
  	42
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 7.626 secs
.../spvc/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../spvc/platforms/android/gradlew with args: cdvBuildRelease,-b,.../spvc/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../spvc/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../spvc/platforms/android/cordova/build: Command failed with exit code 8
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
PaulF_IntelCorp
Muthaiyan -- are you still seeing this build error? The build log is complaining about a PNG file that is not a PNG file. I can't tell what the file is, but I'm guessing that you've included some splash screen or icon files that might be bad?
PaulF_IntelCorp
Timothee -- can you provide a sample app that illustrates the problem? Zip the entire project directory and attach it to this thread. I don't know how to create this error, with a test app that generates the problem we can figure out what it is going on.
PaulF_IntelCorp
Timothee -- the error messages are correct:
* What went wrong:
Execution failed for task ':mergeReleaseResources'.
  	/Developer/android-sdk-linux/build-tools/22.0.1/aapt s -i .../forum_559561a/platforms/android/res/drawable-port-hdpi/screen.png -o .../forum_559561a/platforms/android/build/intermediates/res/release/drawable-port-hdpi-v4/screen.png
  Error Code:
  	42
  Output:
The error message refers to a file named "screen.png" -- which is what each of your splash screens were renamed to before they were moved into the build project resource directories. Unfortunately, you supplied JPG images as your splash screen images, not PNG images. So the files were renamed, but they were not converted from JPG to PNG.
Convert your splash screen images to PNG format and things should work. I will alert our build engineer regarding this issue.
PaulF_IntelCorp
Timothee, please read the full text of the message you are pointing to, especially this paragraph:
We do not have a solution for this issue, at this time. We are working on finding an adequate short-term and long-term solution. Some of the issues are legal restrictions surrounding the hosting and redistribution of third-party libraries. So this is not just a simple technical issue. This problem only applies to Android and Crosswalk builds and should only be seen when using CLI 5.1.1.
and these paragraphs:
Workarounds include:
  • using an older version of the plugin that is causing the problem (determining which plugin is the culprit cannot be easily deduced from the error message, so you have to remove plugins one at a time and rebuild your app to figure out which is causing the problem)
  • using the CLI 4.1.2 build option (which uses ANT rather than Gradle to build Android images)
  • using a combination of both of the above workarounds (older plugin and CLI 4.1.2)
  • looking for a branch or fork of the offending plugin that does not rely on this new technique for specifying the inclusion of external third-party libraries (see the technical details section below)
In your case, I believe you need to explicitly request version 1.2.3 of the push plugin you are using, rather than the default version of 1.3.0. You'll have to specify this in the version field when you add the plugin (remove the plugin, add it again, but specify 1.2.3 rather than leaving the version field blank).
