Software Archive
Read-only legacy content
17060 Discussions
Can't scroll listview
Emad_R_
Hello I create subpage to list all cars
and this listview get data from ajax (DB)
but I can't scroll down just I can see only first 3 items
here my code
                <div id="cars_index" class="upage-content vertical-col left ">
                    <div class="widget uib_w_5 d-margins pages_title_header" data-uib="media/text" data-ver="0">
                        <div class="widget-container left-receptacle"></div>
                        <div class="widget-container right-receptacle"></div>
                        <div>
                            <p>All Cars</p>
                        </div>
                    </div>
                    <ul class="list widget uib_w_6 d-margins" data-uib="app_framework/listview" data-ver="1" id="listcars">
                        <li class="widget uib_w_9" data-uib="app_framework/listitem" data-ver="1"><a>List Item</a>
                        </li>
                    </ul>
                </div>
            $ (document) .on ("click", "#mainpage_to_cars_index", function (evt) {
        $ ("#listcars") .empty ();
            $ .ajax ({
                type: "GET",
                url: "http://localhost/api/cars.php",
                timeout: 3000,
                contentType: "application / json; charset = utf-8",
                // dataType: "jsonp"
                success: function  (result, jqXHR) {
                    var  cars = JSON.parse (result);
                    $.each(cars,function(i, car){
                    var item = "<li><h2>"+car.car_year+"</h2><p><b>Make:</b> "+car.car_make+"</p><p><b>Model:</b> "+car.car_model+"</p></li>";
                    $("#listcars").append(item);
Please Help
Emad_R_
Fixed I added
overflow-x:hidden
Elroy_A_Intel
The overflow CSS property as you previously mentioned allows for you to enable scrolling.
URL: http://www.w3schools.com/cssref/pr_pos_overflow.asp
Mauro_F_
hello I have the same problem, but I can not solve it.
Despite using "overflow-x: hidden" I can not have the scroll.
Maybe it applies evil overflow-x: hidden.
Can you give me an example of a code of how to apply the solution.
Thanks a lot
Sorry for my english
Mauro from Italy
Brian_W_Intel
Emad and Mauro,
Well your HTML and Javascript look alright, and since you're getting three results to show up I'm guessing everything is running ok. Since I can't run your local cars.php, I can't tell what it's returning, but that's where I would look. Inside your success callback function, in the $.each(cars...) is the cars object bigger than three items? There's nothing in the code that would limit it to three items, so my guess is that the cars object you're getting only has three items, or something is wrong in there in a way that you're only getting a few items appended to your unordered list.
Brian
Mauro_F_
Hello Brian
the problem is very simple.
If, as in this example, I insert a list that is unlocked.
Does not scroll.
I tried to enter various properties as "overflow-x: hidden" but the scroll does not work on Android.
I'm using "App Framework" and tried on Galaxy S5 Mini with Android 4.4.2.
Tell me what other information you can serve
Thanks a lot for the collaboration
Mauro
            <div scrolling ="no" class="upage vertical-col panel" id="mainpage" data-header="af-header-6" data-footer="none">
                <div class="grid grid-pad urow uib_row_1 row-height-1" data-uib="layout/row" data-ver="0">
                    <div class="col uib_col_1 col-0_12-12" data-uib="layout/col" data-ver="0">
                        <div class="widget-container content-area vertical-col">
                            <ul class="list widget uib_w_2 d-margins" data-uib="app_framework/listview" data-ver="1">
                                <li class="widget uib_w_8" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_1" data-transition="fade">List Item</a>
                                </li>
                                <li class="widget uib_w_7" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_2" data-transition="fade">List Item</a>
                                </li>
                                <li class="widget uib_w_6" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_3" data-transition="fade">List Item</a>
                                </li>
                                <li class="widget uib_w_3" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_4" data-transition="fade">List Item</a>
                                </li>
                                <li class="widget uib_w_4" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_5" data-transition="fade">List Item</a>
                                </li>
                                <li class="widget uib_w_5" data-uib="app_framework/listitem" data-ver="1"><a href="#uib_page_6" data-transition="fade">List Item</a>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                                </li>
                            </ul><span class="uib_shim"></span>
                        </div>
                    </div>
                </div>
            </div>
PaulF_IntelCorp
Mauro, please try this in a Crosswalk build (or using the Debug tab, which uses Crosswalk). I'm guessing that you are running into the bad webview problems associated with Android, thus the reason we offer Crosswalk as an alternative for Android.
