Software Archive
Read-only legacy content
17060 Discussions
IOS build error
Josef_J_
I can't build ios anymore , anyone one knows what that error log means ?
http://hdmx.com/error.txt
John_H_Intel2
Anymore? Have you ever successfully built an iOS app?
The reason it failed is at the bottom of the log file. Your app id you entered in the XDK does not match what you created your provisioning profile with on apples developer portal.
Josef_J_
John , yes i did that is why i said anymore !
i will create another profile and see !
Josef_J_
Nothing helps , i keep getting this error
An unexpected error occured while attempting to build the application.
** BUILD FAILED **
The following build commands failed:
    Ld build/okvol2apple.build/Release-iphoneos/okvol2apple.build/Objects-normal/arm64/okvol2apple normal arm64
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../okvol2apple/platforms/ios/cordova/build-release.xcconfig,-project,okvol2apple.xcodeproj,ARCHS=armv7 armv7s arm64,-target,okvol2apple,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../okvol2apple/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../okvol2apple/platforms/ios/build/sharedpch
Command finished with error code 2: .../okvol2apple/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../okvol2apple/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
John_H_Intel2
Are you sure the iOS cordova builds that you have completed in the past were built with the same account? (the same email address that you use for the forums).
This account only started building Sept 24, 2015 and has only built cordova android apps until today. It has never successfully built an iOS app?
Is there another account you could be using? If so, it would have a different certificate, which is whey things dont match.
Josef_J_
John
here what happened , after the update to the new version non of the old apps worked so i had to rebuild all and deleted the old apps from  the app center, all android apps working fine but  i can't build IOS apps . i used always the same account and created a new certificate for this app but with no luck!
I sent you a link to the app that i built in the appstore !
thanks for your help !
PaulF_IntelCorp
Try these AdMob options:
or
