Software Archive
Read-only legacy content
Build Error
Spiros_N_
Today a project that was building without problems 2 days ago returns error
no problems with IOS build where ca I get a log with more details ?
John_H_Intel2
Are you including any 3rd party plugins? If so, try removing them and reuploading/building and see if the build works then.
PaulF_IntelCorp
I just heard back from the engineer in charge -- there is a bug associated with Crosswalk and local imported plugins. The fix is in process and after testing has been completed it will be moved to the production build system. With luck that will happen sometime this week.
Spiros_N_
Great news Paul !
Gary_H_2
Any update on when we can expect to be able to use local plugins again with Crosswalk builds?
PaulF_IntelCorp
Still working on it. Sorry, I can't publish a date due to company policy. I know that's a lame answer, but Intel is very strict about things like privacy and delivery dates...
PaulF_IntelCorp
The build engineer has pushed some fixes to our production Crosswalk build system that we believe fixes the issues you are seeing with local plugins. Please give it a try and report back on this thread.
Gary_H_2
Hooray, its working again. :-)
Thanks for getting it fixed.
Gary_H_2
Maybe I spoke too soon. :-(  Seems hit and miss now if it builds. Can't do 2 builds in a row without taking out the local plugin then adding it back in.
Shay_s_
What a bad timing for me that was to test a local plugin... I have just tried building with a local plugin and I have decided to remove it, but ever since I have removed the local plugin, the building takes a long time and eventually fails, without giving any crash log.
Is there a way of tracking the build error manually? I have no idea what went wrong!
EDIT: It seems like the build also takes a really long time (about 15 mins) and eventually fails with a backup, and with a fresh new project. So I guess it's something to do with the server?
Spiros_N_
A more detailed log would be good for the build process. Like the one that is available on successful buld.
Ian_J_
I am seeing this issue for the first time today.
Last night I made about 20 builds without issue, today I am unable to build.
PaulF_IntelCorp
I just did a test Crosswalk and Android build with a local plugin and the build worked. Please try again.
Shay_s_
All working now... Thanks for the amazing build tools. :)
Gary_H_2
For my project I can confirm that the Crosswalk build system is behaving itself today and I have had no issues since last night.
