Software Archive
Read-only legacy content
17060 Discussions
Build Failed, Error Plugin Google Play Services...
Carlos_Y_1
Please let me know if anyone can help me? I'm implementing Onesignal Push notification in my App, but when I go to Builder it returns the error below:
TID: https://documentation.onesignal.com/docs/intel-xdk-setup
BUILD FAILED:
Build Log
Error: Plugin Google play services for android failed to install.
Error: Plugin Android Support v4 failed to install.
Thank you,
Yajima
Carlos_Y_1
Hi Paul,
I made a mistake, I needed to omit android-support-v4 if in case I used Crosswalk 16 or newer ... as you said: caused a version conflict.
* Do you think of implementing any Push Notification service (easier) under Intel XDK in the future??? :)
Thanks for your help!!
PaulF_IntelCorp
Carlos -- we do not implement the plugins you are using, we are simply providing a front end to build standard Cordova apps that use third-party Cordova plugins. Search the Cordova plugin registry for other push services.
