Software Archive
Read-only legacy content
17060 Discussions
Build crash with cordova-plugin-admob
Hamilton_Tenório_da_
Valued Contributor I
I am using XDK 2807 and trying to use cordova-plugin-admob. It always broking the build (Cordova Android).
I search and found a issue about it (https://github.com/floatinghotpot/cordova-plugin-admob/issues/206) and the user post a solution: download the plugin from the web, and then instal it from your own directory :)
I did it and the build was OK.
Is there a known problem? How to use the server plugin?
Amrita_C_Intel
Hello Hamilton,
I created and blank project with the same plugin and the build was successful. I used third party plugin and selected git repo and copied the URL. Try doing that or try building a blank project with that plugin.
@Amrita,
I did some more tests. For me, the problem is occuring only with Cordova CLI 5.1.1 Crosswalk 15. Another cases using CLI 4.1.2 CW 14 is OK.
Amrita_C_Intel
Hello Hamilton,
I built with both the CLI versions and the built is successful in both the cases. Can you retry now?
If the build is failing can you send the build log?
Hi Amrita,
This issue is very odd. I tryied with a new app (for test) and build OK. It seems that there is a particular configuration in first one.
To confirm this situation, I did this:
- duplicate my project to test
- build iOS (success: local plugin) --> see log attached
- remove the local plugin
- insert the repo admob
- build iOS (failed) --> see log attached
Thank you for your attention.
