I export my project via C2, using "WKWebVIew on iOS" and "Use new Intel CDK project format"
After setting up everything in XDK I get the following error when trying to build for iOS:
"Error: Please specify a supported Cordova version (5.1.1 or 5.4.1)."
This happens when 5.1.1 is selected and when 5.4.1 is selected
- Tags:
- HTML5
- Intel® XDK
Can you private message me the context of your project's .xdk file? This will help with identifying your issue.
Same problem here. With XDK 3088, via C2.
Hello, I am having the same problem as well exporting from Construct 2 using Cordova for Intel XDK 3088.
I keep getting the same error "Error: Please specify a supported Cordova version (5.1.1 or 5.4.1)."
I've even tried downgrading to 5.1.1 but the error persists.
Has anyone found a solution yet?
no solution but a workaround is to build the project as you did until now:
Don't use "Use new Intel CDK project format", instead uncheck it and import to XDK via "Start a new Project".
That is still working for me, don't know if you can use WKWebview then though.
Thanks for the feedback - not a great workaround - I doubt WKWebview will work without the new format. I'll give it a shot though.
Do you use any of Cranberry's plugins? I am wondering if that might be causing issues?
Yes I am using UnityAds and Flurry Plugins from Cranberry
Doesn't seem to be the Plugins causing any issue - I tried removing the Cranberry ones but still had the same error.
Another workaround: use phonegap together with this: https://www.scirra.com/construct2/releases/r224
Haha yes that is what I am going to for this build do until this issue is sorted out. Thanks!
We're still working out some kinks in the new Construct2 export. It looks like this line is missing from the <project-name>.xdk file in the iOS and Windows sections of that file. For example, you should find something like this in a properly formatted:
"iOS": {
"platform_": "ios",
"runtime_": "Cordova 3.x",
"name_": "iOS",
"preferences_": {
The problem is this line is missing (from the iOS and the Windows sections in that file):
"iOS": {
"platform_": "ios",
"name_": "iOS",
"preferences_": {
If you add that missing line into the <project-name>.xdk (when the XDK is closed) and then open the project it should fix the build problem.
Thanks for the feedback and update!
