Software Archive
Read-only legacy content
17060 Discussions
Build fails with XDK 2366
Tony_B_
Good morning,
I downloaded the new XDK 2366 and now find that a Crosswalk-Android build fails almost immediately with "An error occurred please check your build assets".. The app itself previously built OK, the only changes I made since the XDK upgrade were to the Projects tab in XDK, several of the fields were previously blank. Attached is a screen shot of the Build info.
Thanks for any advice,
Tony
PaulF_IntelCorp
Are you still experiencing build failures? Nothing unusual about the Projects tab image you provided.
Tony_B_
Hi Paul,
I just tried the Android crosswalk upload/ build again. Upload worked and the build failed within a few seconds with "An error occurred while building the application. Verify your build assets are correct and try again."
The only changes I made were to the build settings, no changes to the App itself.
Tony_B_
Hi Paul,
In case it helps I uploaded the app to Dropbox. Here's a link https://www.dropbox.com/s/bpz135011qgruql/TSLEQR.zip?dl=0
Thanks again,
Tony
Gerrell_J_
I am having the same issues. It uploads but then fails. Last build test is 9/20/2015 9:57 AM
john_h_12
@Gerrell J
We need more info. Platform? Settings? Did you change something and now it does not build?
Tony_B_
Hi Gerrell,
I'm using XDK 2366 on Windows 7. I made no changes to the app, just updated some of the build settings as shown attached to an earlier post. The app is also available on Dropbox with a link also shown in an earlier post.
Tony
John_H_Intel2
I am also having issues building. This isnt official, but it looks like AWS is currently having issues.
Hamilton_Tenório_da_
Valued Contributor I
I am using with no problem (Crosswalk Android building). It is working OK.
PaulF_IntelCorp
@Tony, the problem is your App ID. A single valued ID is inadequate, it needs to contain at least two parts. If you try the regular Android build you'll see the error message, unfortunately, the Crosswalk build is not providing that level of detail. I've attached the error message from the Android build. I did a test with the Android build because it builds faster and usually whatever is ailing a Crosswalk build will also be ailing an Android build.
I recommend you use at least a three part App ID, for example, something like "com.mydomain.myappname"
Tony_B_
Hi Paul,
The App ID was the problem. The build works now. Thank you very much again for the assistance.
Tony
