Software Archive
Read-only legacy content
Buttons not working after insert a sidebar!
Braglin__Fabio
Dears,
I have an very simple app that was made using Ratchet framework, now I want to improve this app and I need to add a sidebar, but after insert this something bad happens. I can't use the buttons well.
  1. My app is already working
  2. Try Emulate tab -> OK
  3. Try AppPreview -> OK
  4. Try Cordova builded apk -> OK
  1. Insert the Animated Sidebar LEFT widget
  3. Try AppPreview -> NG
  4. Try Cordova builded apk -> NG
After I add the sidebar I must press the buttons 4 or 5 times (quickly!) to works.
Any idea?
Anusha_M_Intel1
The buttons that were working before sidebar is no longer working now? If it is working when pressed simultaneously, I would think your controls might be overlapping or some div issue. Can you check if all your open and close tags match?
Could you paste a sample code or zip your project and send through IM?
Braglin__Fabio
Hello Anusha,
I already check the divs, but I can't find nothing wrong, so I changed from ratchet to AppFramework and it works now... strange no?
I turned back to Ratchet and it is not working again.
So I changed to AppFramework and apply the Ratchet css.
Thank you for your attention,
Fabio
Anusha_M_Intel1
Glad it worked out for you. There are plenty of app framework samples that ship with the XDK for your reference. Good Luck!
