Software Archive
Read-only legacy content
17060 Discussions
CASE construct, but with reals
Intel_C_Intel
Apparently I can't use a REAL variable as the case expression in a CASE consruct. Is there any similar construct in which I can do effectively the same thing using a REAL, or am I relegated to a series of IF ... THENs?
Nope - can't use REALs. Keep in mind that comparing REALs for equality is often a source of trouble, as sometimes a computed result isn't exactly the decimal value you think it is. Depending on what your values are, perhaps you could convert the value to integer and CASE on that?
Steve
Intel_C_Intel
Thanks, anyway. Yes, I am familiar with the hazards of comparing reals.
Now I just have to decide which is uglier, the IF..THENs, or the conversion to an INTEGER case expression.
