Software Archive
Read-only legacy content
17061 Discussions
CREATE AN IOS CERTIFICATE CSR FILE IN XDK NEW LAYOUT CORDOVA 5.4.1
Leonidas_S_
5 - On an Apple OS X* system, click Continue to create a CSR.
If you do not have an Apple OS X system and have not yet uploaded a certificate to the Intel XDK build system, you can create a CSR file using the Intel XDK Build tab:
  • In the Intel XDK Build tab, click the iOS build tile.
  • Click the Edit button next to iOS Certificate.
  • In step 1a, click the download button and save the CSR file to your local system.
https://software.intel.com/en-us/xdk/articles/walkthrough-obtain-ios-dev-cert
HOW CREATE AN IOS CERTIFICATE CSR FILE IN XDK NEW LAYOUT CORDOVA 5.4.1???
IN THE MID I CONVERTED A CERT P12 FILE BUT GETTING ERRR ON BUILD:  // IS IT FOR THIS REASON THE ERROR...?
"Code Sign error: No codesigning identities found: No codesigning identities (i.e. certificate and private key pairs) that match the provisioning profile specified in your build settings (“March2016PC-08-03-iOS”) were found.
Elroy_A_Intel
I recommend that you create new iOS certificate to access associated P12 file appropriately. For more information visit https://software.intel.com/en-us/xdk/docs/intel-xdk-certificate-management#view-create-import-apple-certs
Leonidas_S_
keep the old P12 migrated (P12 file from legacy) ?  basically P12 created independently? where needed/linked the P12 in the provisioning profile file creation???
PaulF_IntelCorp
Leonidas -- you can keep the migrated P12 certs and continue to use them. If they no longer work, it is easiest and simplest to simply create a new set using your Apple Developer account.
See this doc page for details about the new way to create build certificates > https://software.intel.com/en-us/xdk/docs/intel-xdk-certificate-management < and see this one for specific instructions regarding iOS certs > https://software.intel.com/en-us/xdk/articles/walkthrough-obtain-ios-appstore-adhoc-cert-and-p12 <
Leonidas_S_
BUILD PAGE YOU CREATED BEFORE CERT SIGN REQUEST
WHERE NOW YOU CREATE THIS... NEW XDK,...?
PaulF_IntelCorp
Leonidas -- please read the text on this page and watch the video > https://software.intel.com/en-us/videos/upgrading-an-existing-intel-xdk-project-to-version-3088 (there is no audio)
