Software Archive
Read-only legacy content
17061 Discussions
surface pro 4 Camera realsense compatibility
Francesco_M_1
I have a Surface pro 4 i7 16gb ram. Can I use a realsense app? Microsoft said YES, but I tried to install some app (Personify and Warrior wave) and don't reconize a 3D camera or driver.
Can somebody help me?
samontab
Valued Contributor II
Make sure you have the DCM installed
Colleen_C_Intel
Look in Device Manager. I believe you'll see at least 3 cameras - 2 RGB that aren't realsense and an IR camera. See wat it is branded.
pablo_r_
Hi, I'm facing the same problem but using the i5 processor version.
I tried to run the app "Raw Streams" and it recognized both RGB and Deph cameras, but it is only able to display a color stream. When I tried with the Camera Viewer it failed setting the depth stream.
I also get into the code, but the SDK throw a "Device unavailable" error.
sensorManager->EnableStream(PXCCaptur::STREAM_TYPE_DEPTH);
auto status = sensorManaget->Init(); // This line returns "Device unavailable"
This is what I see in the Device Manager
pablo_r_
I tried reinstalling the DCM again, but this time I disabled the embedded camera, and it started working. Something might went wrong the previous time.
Francesco, did you tried that?
Francesco_M_1
Hi guys,
BAD NEWS...
this is the Microsoft answer:
Please be advised that the Intel Realsense SDK is not yet compatible with our Device Surface Pro 4. I have checked and tested it on my end.
We do apologize for the inconvenience. I sent an email to our Development Team regarding the software Realsense SDK software.
Again I am sorry to inform you that the software is not compatible with our Device yet.
Any Ideas?
pablo_r_
Well... What does it mean not compatible yet?
I'm using it without problems since the other day.
Francesco_M_1
Hi Pablo,
I mean a INTERNAL Surface Pro 4 Camera! ;)
