Software Archive
Read-only legacy content
17060 Discussions
Camera installed but it seems I need another driver
Alarcon_Palomar__Osc
I'm having problems installing Intel RealSense 3D F200 camera on a Windows 7 64bit Ultimate with an Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz and 16Gb de RAM.
I have attached an Image to show what I see on my device manager and a text file with all the info get with SDK Info program.
On Device Manager appears installed Camera Depth (F200) Depth and Camera Depth (F200) RGB, but it isn't installed Camera Depth (F200).
How can I fix this problem?
samontab
Valued Contributor II
Make sure you have the DCM installed as well as the RealSense SDK. You need to install two things.
DCM and SDK are installed.
Henning_J_
Don't the RealSense cameras require at least Windows 8.1?
samontab
Yes, you're right Henning.
You need Windows 8.1 or 10 to use the SDK.
