Intel Hello?
In my application I am saving images obtained from the camera (though not from the face recognition module) into a sqlite database from C#. I'm not sure how similar to your case this is (as you haven't given much information), but it may help.
You can do something like:
PXCMImage.ImageData data; PXCMCapture.Sample photo = pSenseManager.QuerySample(); PXCMImage image = photo.color; image.AcquireAccess(PXCMImage.Access.ACCESS_READ, PXCMImage.PixelFormat.PIXEL_FORMAT_RGB24, out data); Bitmap bitmap = data.ToBitmap(0, image.info.width, image.info.height)); //then when you want to save: ImageConverter converter = new ImageConverter(); byte[] imgData = Compress((byte[])converter.ConvertTo(bitmap, typeof(byte[])));
Then you can just insert the imgData variable into your database. I'm sure your favourite search engine will help you out if you don't know how to do that already.
