Software Archive
Read-only legacy content
17060 Discussions
WPF Face Recognition error.
Hermawan_R_
in my code for saving the recognition file, the "nbytes" variable always return null value. but when I try to develop in winform, it runs no error. and this is the part of my code.
private void registerButton_Click(object sender, RoutedEventArgs e)
            faceData = face.CreateOutput();
            faceData.Update();
            var numOfFaceDetected = faceData.QueryNumberOfDetectedFaces();
            if (faceData.QueryNumberOfDetectedFaces() <= 0)
                return;
            PXCMFaceData.Face qface = faceData.QueryFaceByIndex(0);
            if (qface == null)
                throw new Exception("PXCMFaceData.Face null");
            PXCMFaceData.RecognitionData rdata = qface.QueryRecognition();
            if (rdata == null)
                throw new Exception(" PXCMFaceData.RecognitionData null");
            PXCMFaceData.RecognitionModuleData rmd = faceData.QueryRecognitionModule();
            Int32 nbytes = rmd.QueryDatabaseSize();
            Byte[] buffer = new Byte[nbytes];
            rmd.QueryDatabaseBuffer(buffer);
            File.WriteAllBytes("text.txt", buffer);
            rdata.RegisterUser();
            id++;
            AddDatabase(id);
            faceData.Dispose();
I check the value of numOfFaceDetected return the right number of face detected. But, when I try to get the nbytes values, it returns null. But when I check in debug mode rmd.QueryDatabaseSize(); has unique value. Any solution? thanks
Xusheng_L_Intel
This is known issue and we will fix it in the future release. Thanks for supporting RealSense SDK.
Thoriq_S_
i think you can save a serialized data to be *.dat file instead of saving it into txt file :D
Thoriq_S_
oh, i suggest you to develop your apps in windows form. i have developed a WPF apps and i got unknown error, but when i develop it in windows form, using same algorithm, i had no error
Adi_P_
I have same problem with you. And I am still looking for solution. I hope anyone who can solve this problem.
Adi_P_
Hi thoriq, can i see your code ?
Thoriq_S_
sorry, i have lost my code..
Xingyi_S_Intel
Hi David,
I saved Face Data to a .dat file. Next time RealSense demo starts, it automatically load the .dat file. But after the same face into Camera's view, RealSense cannot recognize the face until about 1300ms later. In other words, after loaded registered face data, RealSense  cannot recognize the face right now. I write the demo reference to DF_FaceTracking, RecognitionModuleData::QueryDatbaseBuffer() is used to save face data, RecognitionConfiguration::SetDatabaseBuffer() is used to load face data. Do anything else need I to do? Thank you.
