Software Archive
Read-only legacy content
17060 Discussions
Can i use F200 for scanning room dimension and create a depth map.
Tosheer_k_
I have a Intel realsense F200 and i like to explore the opportunity to using F200 Depth Camera and measure the room dimension using this. Later on use this depth map for virtual fitting of furniture suggestion.
<br>
Can you guys tell me if i can use the F200 for creating the depth map, as i can't see any depth details when i check the stream from depth stream.
Ariska_Hidayat
I thought it could not scanning a room. due to limitations of distance to create a depth. I think that is able to do camera distance is approximately 30 cm. it is possible to scan an object.
Ariska_Hidayat
I think just using R200 which can scan room dimension.
samontab
Valued Contributor II
Of course you can. Just get the depth frame, and get the X, Y, Z coordinates of those points.
Now you have a point cloud. You can process it further and generate a full 3D map of the room. It is not a simple process though.
