Software Archive
Read-only legacy content
17060 Discussions
Can only use DVI-HDMI when X3100 Drivers not installed
falcontime
If I uninstall the drivers, I can get output to my DVI-HDMI cable. Otherwise, the screen says NO SIGNAL and is black. If I use safemode, I can use it too.
Any known fixes? I keep trying different things, but no luck. Here's my info for the HDMI port(only can get it from moninfo is without the drivers)
Monitor
Model name............... ZORAN HDMI TV
Manufacturer............. ZRN
Plug and Play ID......... ZRN0294
Serial number............ 1
Manufacture date......... 2005, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 640 x 360 mm (28.9 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 1.00
Red chromaticity......... Rx 0.635 - Ry 0.337
Green chromaticity....... Gx 0.281 - Gy 0.600
Blue chromaticity........ Bx 0.145 - By 0.078
White point (default).... Wx 0.289 - Wy 0.304
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-60kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 120MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #2....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video data (timings supported)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 08.29.2009
Software revision........ 2.30.0.797
Operating system......... 5.1.2600.2.Service Pack 3
Raw data
00,FF,FF,FF,FF,FF,FF,00,6A,4E,94,02,01,00,00,00,00,0F,01,03,80,40,24,00,0A,92,03,A2,56,48,99,25,
14,4A,4D,21,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
25,00,F4,19,11,00,00,9E,01, 1D,00,72,51,D0,1E,20,6E,28,55,00,F4,19,11,00,00,1E,00, 00,00,FC,00,5A,
4F,52,41,4E,20,48,44,4D,49,20,54,56,00, 00,00,FD,00,3B,3D,0F,3C,0C,00,0A,20,20,20,20,20,20,01, 22,
02,03,18,71,45,07,02,03,04,05,26,09,07,07,15,07,50, 66,03,0C,00,10,00,80,8C,0A,A0,14,51,F0,16,00,
26,7C,43,00,F4,19,11,00,00,98,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,90,2D,11,00,00,18,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,37
