Software Archive
Read-only legacy content
Can't Install RealSense SDK
Rich_C_
Trying to install the SDK; both web setup and offline crash silently with no error after "Extracting configuration files".
Running Windows 8.1 Enterprise 64 bit on an i7 machine, can't see anything in the event logs, any ideas?
samontab
Valued Contributor II
Couple of ideas:
- Do you have enough space in your disk?
- Try running it as admin.
Rich_C_
Thanks for the ideas, still a no go though. :(
50GB free on my system drive, and running as admin has same result.
samontab
mmm. Strange.
- Try restarting the computer (maybe some process is using something).
- Execute the installer from the command line, maybe some error will be written to the console.
Vidyasagar_MSC
Innovator
Did you check application/System and other logs? If yes Pls run any windows updates and restart your machine.
Once done pls try to install once again
Colleen_C_Intel
Make sure you have the August update from Microsoft
