Software Archive
Read-only legacy content
17061 Discussions
Can't start the RealSense DCM Windows Service
Avihai_R_Intel
Hi guys,
Hope it's the right place to ask, I have the F200 camera and installed the RealSense SDK. I couldn't run any sample, so I investigated and saw that I can't start the DCM Windows Service. When I try to start it, it says:
Windows could not start the Intel(R) RealSense(TM) Depth Camera Manager Service on Local Computer.
Error 0x80010119: Security must be initialized before any interfaces are marshalled or unmarshalled. It cannot be changed once initialized.
I'm running Windows10-64 bit , and the DCM version I'm running is 1.4.27.41944.
Can someone help? :)
Avihai
Colleen_C_Intel
I'd suggest going to Control Panel>Programs and uninstalling the Intel Depth Cam Manager. Then reboot. Then either install from the software.intel.com/realsense website WITH ADMIN privileges - or allow windows update to re-install.
If that fails, please attach your log files fournd either at \\C:\Windows\Temp\micl_tmp_SYSTEM\2016.XXXXXXXXXX\log or  %TEMP%\micl_tmp_%loginname%   (or just search on your system for micl).
Avihai_R_Intel
Hi Colleen,
I've removed, rebooted and re-installed with admin privileges but the problem persists.
Attaching the log files to the message.
Avihai
Avihai_R_Intel
Hi, any update on this?
Tried to uninstall and install again using admin privileges to no avail.
Avihai
GEORGE_V_1
I am having the same problem. Have installed and uninstalled the manager software several times.
Peter_W_4
I'm also having this problem.
tprim1
having the same problem here
this service used to work form me
reinstaiing the DCM didn't help either
caddit
518409
Dear intel,
Same problem here too. install log attached - although many of the messages are not helpful to me.
Also Windows 10 x64 (Pro Edition) ... with NVIDIA GTX 960M, I7, plenty of RAM and HD.
Spent a lot of time trying multiple driver and SDK versions too. More reboots than I can count. Very annoying.
How do we fix this? Please advise otherwise I will be returning the device.
caddit
Well,
Glad I wasn't holding my breath for any support from this company.
DO NOT BUY THIS DEVICE. IT'S A WASTE OF TIME BECAUSE OF BAD SOFTWARE.
The Intel Realsense driver and SDK is one of the WORST Windows drivers I have EVER seen -> won't even INSTALL without errors (Windows 7 had another issue - something about needing a kernel-level driver KB installed that it refused to recognize - even when the KB WAS installed). Making matters exponentially worse is the COMPLETE LACK of product support (just look at this thread, say no more..).
I have a FULL REFUND from the supplier since this country has laws protecting consumers againt DEFECTIVE PRODUCTS. Meanwhile I went and bought another 3d scanner having a driver less than a tenth the download size of this paperweight, and guess what - it worked just fine. First time too, no extra windows services and other convoluted rubbish "architecture".
Bad Intel. Bad. Go to your room!
shuji_n_
Had the same problem, but it was solved.
In my case, the cause of problem was Microsoft Office2010.
I'm not sure, but, I think Office2010's Runtime or something is effected on the problem.
It was solved by Windows Recovery.
Hope it helps.
