Software Archive
Read-only legacy content
17060 Discussions
Cannot run Intel XDK anymore
Jakub_K_3
2 days ago I could open and use Intel XDK without problems. From yesterday I cannot open it.
Those are the steps I make:
1. http://ctrlv.in/651251
2. What I get is: http://ctrlv.in/651252
And nothing more...
Some notes:
1. I tried to delete global-settings.xdk - no results.
2. I checked log - nothing appears.
3. Path is C:\Users\me\AppData\Local\Intel\XDK\bin\nw.exe
4. When I run C:\Users\me\AppData\Local\Intel\XDK\bin\xdk.cmd instead - it works, but cmd window won`t disappear.
5. I dont want to reinstall Intel XDK again... I have few custom plugins for brackets installed.
6. Win 7 64-bit
Jakub Król.
PaulF_IntelCorp
Jakub -- I think there is something wrong with your installation, which might have to do with the custom Brackets extensions... Please follow the instructions on this page: https://software.intel.com/en-us/forums/topic/542074 and then install 2548 from http://xdk.intel.com.
Regarding your custom Brackets extensions, I recommend you just install and use Brackets outside of the XDK, then you can use ALL the available Brackets extensions AND use the latest version of Brackets. I do this all the time, with both Brackets and Sublime. You are not required to use the editor built into the XDK, using an external editor works just as well. The XDK monitors file activity so it will see when a project file has changed.
